New clutch= rough rowing gears
Old Nov 26, 2013 | 11:13 AM
mr84monte's Avatar
Since installing the stage 3 KY clutch and rotated mounts (I have less than 300 miles on the install) today was my first day driving it to work, and it was miserable. If you go more than a couple of miles without shifting, it doesn't like to come out of gear easily. In fact you almost need to go clutch..release..clutch then it comes out. I was going to give the mechanic a call today to see if he has any ideas.
Because of the rotated mounts/new clutch, is it possible that the shift linkage to the shifter needs to be adjusted?
Old Nov 26, 2013 | 11:15 AM
blueLNFftw's Avatar
It needs bled. The master/slave does.
Old Nov 26, 2013 | 11:17 AM
CoBOLTingSS's Avatar
Try this method for bleeding
Old Nov 26, 2013 | 11:18 AM
Sox-Fan's Avatar
Got Brakes?
There is no shift linkage. It's cables. They don't care if you rotate the transmission/engine package a few degrees. Rotated mounts don't do that, at least mine didn't. Pretty sure Corey is right, bleed the ToB again.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
