Is this normal (please help!!!)
Old 07-08-2013, 04:50 PM
Terminator2's Avatar
Originally Posted by Nate08SS
The one pending code is the same as the p2227 lol . But the only thing I've noticed is the boost recently decreased from 20+ to like 15-17
Sounds like a stock GMS1 tune to me but only one way too see for sure. Someone needs to hook up a hp tuners cable and do a read entire to pull the tune file see what tune is in the ECM. Try what I suggested above with swapping the top and bottom sensors and make sure they are clean and see what happens.
Old 07-08-2013, 04:57 PM
Nate08SS's Avatar
Okay I will thanks! Would I have to buy hp tuners or do dealers have them
Old 07-08-2013, 06:17 PM
No dealers do not have hp tuners, look for a performance shop, specifically a GM performance shop. If you want to have the vehicle tuned by someone remotely (e.i. Term2) then I would buy Hp tuners otherwise just have a performance shop pull the data.
Old 07-08-2013, 06:25 PM
Buying it is the easiest way unless you know someone with hp tuners.
Old 07-08-2013, 07:58 PM
SSlobalt's Avatar
Just so you guys know, with the cold side TMAP sensor, the "T" stands for "temperature." The TMAP sensor has pressure and temperature feedback. The MAP sensor in the intake manifold only feeds back pressure. That is why there is an extra wire: because the pigtails are the same and we are not using the temperature feedback wire.
Old 07-09-2013, 12:32 AM
Nate08SS's Avatar
Okay so i pulled and cleaned the sensors (werent very dirty) and switched them. Still the same problem. I dont have a performance shop near me that i know of, and really have no clue where to go to have my tune looked at. What i want to know is if i bought a trifecta tune, would it just overide the current tune, giving me a fresh start?
Old 07-09-2013, 11:12 AM
Before any tuning is done we need to figure out the issue. A good mechanic needs to look over everything and scan the car with a Tech2 tool to hopefully find the issue. You might have to bring it to the dealership for this.
Old 07-09-2013, 04:28 PM
Nate08SS's Avatar
I found out out of raw luck someone I used to work with is actually a trifecta dealer! He has all of the scanners and tools I will need to diagnose the problem and retune if need be. So whenever he gets a chance he's gonna look at it
Old 03-14-2014, 09:47 PM
stevenwhaley89's Avatar
did you ever figure out the problem? i'm having trouble with my barometer too and it's driving me insane
Old 03-15-2014, 12:09 AM
Nate08SS's Avatar
It turned out I was tuned for 2 bar map sensors when I had 3 bar. I got a retune and everything was good
Old 03-15-2014, 12:30 AM
  #36
hmm, well i'm stock besides the Hahn CAI and just had my ECM reprogrammed with the stock tune. the barometer is still shitting out on me
Old 03-17-2014, 01:26 PM
  #37
Nate08SS's Avatar
sorry to hear.. I wish I knew more about it! hopefully someone knows.. i remember looking all over the internet when i had this code and it was hard to find anything that helped aside from this thread
Old 03-17-2014, 02:03 PM
  #38
CudaJoe's Avatar
stock tune with a Hahn intake maybe your problem. Did you try switching back to the stock airbox and see if the problem comes back (after reseting the ECU)?
Old 03-17-2014, 06:12 PM
  #39
i would try that but i don't have the stock air box. i bought it used and it had the hahn on there already. i'm sure i could find one somewhere i just haven't really tried.
Old 03-17-2014, 06:17 PM
  #40
i rewired the map and tmap sensors. but still the BARO reading comes and goes. i also just bought an AEM dry flow filter. no more oil filters for me after sticking a qtip down in the lower charge pipe and seeing all the nasty **** thats in there. i should probably look into getting that cleaned out. anybody know if it's as easy as just undoing the clamps, wiping her out, then putting it back? can't be to hard.
after the switch to the AEM, the BARO reading seems to work more frequently but it's still not 100%. we'll see in the next few days or so
Solaris99
28
03-15-2017 01:22 PM
Jimmy Beilfuss
10-05-2015 04:18 AM
roth
09-26-2015 12:16 PM
Quick Reply: Is this normal (please help!!!)
