OMFG BYTuned - 31+ VE
Hmm, that is very curious. VE airflow should always be lower than or equal to MAF because VE airflow is measured at or near the turbo pumping and other frictional losses must be taken into account. My MAF is 34 lbs/min max but my VE airflow is 31.4 lbs/min max.
VE is not measured anywhere in the engine. Its an ecm calucation using several sensors, and is different throughout the rpm band.
That is why you should always get a stock baseline on the same dyno so you can see the gains. Some dynos read lower or higher than others but the gains are normally the same percentage wise. Just post them up. The torque should be very high if you are running 25+ psi in the mid range.
ok i dyno at smg everytime. i didnt get a chance to dyno stock but my trifecta was at 274whp 305wtq and this new tune got me 298whp and 365wtq
it spiked up to that then kinda dropped down. so my low end is crazy but i need more top end. im happy overall
That's cool, to be expected from bigtime midrange boostages!
Airbox mod or intake & catless DP will help the top end. It'll breath better.
