P0089 and P236 after new LDK install
Old Jun 2, 2015 | 11:41 PM
sixgear's Avatar
Just installed new engine and drove car a couple of miles when CEL came on and car in limp mode, I smelled fuel shorty after getting car started and could not find the source until looking closer and then I seen fuel coming out from under intake manifold so I am guessing injector seals and O-rings which I did not replace or know to replace so I am thinking this leak is the reason for the P0089 code. When I had the intake off during engine swap I sprayed carb cleaner in the intake to clean it up, I figure I screwed up or dirtied up a map sensor and maybe this is the P236 code and maybe the cause of limp mode. I have new seals and O-rings and tool ordered. Do I put the injectors in the rail before mounting to head or injectors in the head and mount fuel rail to it? Also can the MAP's be cleaned and tested?
Old Jun 3, 2015 | 01:50 AM
Grave's Avatar
The injectors go in the rail first. You'll want to alternate bolts to keep the injectors straight as they're going into the head. The leak could be from the high pressure fuel pipe also. The fittings are tightened to 21 or 22 ft. lbs.
Old Jun 3, 2015 | 02:05 AM
Sl0wbaltSS's Avatar
Just get a whole new fuel rain and injectors pre installed. It's easier.
Old Jun 3, 2015 | 02:26 AM
exninja's Avatar
It's not hard. Not worth getting an entire fuel rail and injectors for.
Old Jun 3, 2015 | 07:00 AM
sixgear's Avatar
The high pressure pipe was not leaking. Is there a way to check or clean the MAP sensors?
Old Jun 3, 2015 | 09:21 AM
exninja's Avatar
I squirted some maf cleaner inside mine with no harm done. I tested mine using a hand-pump vacuum and watching the readings on my obdii software compared to the pump's gauge.
Old Jun 5, 2015 | 10:30 PM
sixgear's Avatar
I think I found the source of the P0089 and maybe part of the P0236, some un-soldered MAP sensors.
Old Jun 6, 2015 | 02:46 PM
sixgear's Avatar
Got seals changed, cleaned map sensors, cleared codes. Now no codes but also no boost. Not sure if its in limp mode or not but has no power, struggles to run 60.
Old Jun 6, 2015 | 05:12 PM
Omiotek's Avatar
No boost means limp mode. Check for vacuum and boost leaks.
Old Jun 6, 2015 | 09:41 PM
sixgear's Avatar
My helper left a shop towel in turbo inlet, no problems now
Old Jun 7, 2015 | 11:07 AM
Omiotek's Avatar
Things happen. Easy to miss
Old Jun 8, 2015 | 01:58 PM
StrykerCC's Avatar
So you're all swapped, running fine!?
COOL!
Old Jun 8, 2015 | 05:18 PM
sixgear's Avatar
COOL!
Yes everything seems to be fine, have about 200 miles on it so far.
dennis69
Oct 20, 2015 07:39 AM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
