P0101 code and NO BOOST
Old Aug 26, 2012 | 10:02 AM
jgerma01's Avatar
Hey guys, have a 2010 SS with GMS1 and K&N drop--in.....thats it as far as mods......was at WOT yes and all of a sudden lost all boost. Check engine light came on abot 20 min later and gave me a p0101 code which from searching can be a number of things.....could it be something as simple as a vacuum leak somewhere.....hopefully not intercooler. Car is NOT in limp mode but as I said I get no boost whatsoever, 0.0 on the RPD.
Any help would be much appreciated
Old Aug 26, 2012 | 10:05 AM
BlackARCA06's Avatar
Check the Ic or charge pipe those like to break under higher boost.
Old Aug 26, 2012 | 10:16 AM
BLAZIN07SS's Avatar
I'm too JDM for you
Broke the intercooler, have fun
Old Aug 26, 2012 | 04:44 PM
Soofisahab's Avatar
This^^^ treadstone tr8 from badnewsracing $285. Not as hard as you think to install.
Old Aug 27, 2012 | 02:49 AM
jgerma01's Avatar
Thanks for the input guys, the general consensus seems to be a a cracked/broken intercooler. Not that I dont believe it can be a broken intercooler but could it be something else........broken or loose vacuum line, bad MAP sensor, dirty MAF etc.....
thanks again....ill be taking it to the dealer regardless, car still only has 26K miles and hopefully they dont give me **** if it is the intercooler that needs to be replaced
Thanks again
Old Aug 27, 2012 | 06:15 AM
SSlobalt's Avatar
Originally Posted by jgerma01
Thanks for the input guys, the general consensus seems to be a a cracked/broken intercooler. Not that I dont believe it can be but could it be something else........broken or loose vacuum line, bad MAP sensor, dirty MAF etc.....
Thanks again
You have GMS1, so they won't give you crap about it unless there are scratches on the underneath side of it. Even one little scratch and they'll say you bottomed-out the front of the car and broke it, which you may have. It's better to just buy a metal IC, anyway, so you don't have to worry about this anymore.
Old Aug 31, 2012 | 01:39 AM
jgerma01's Avatar
Well its not the intercooler......at least from what i could see......had the car up on jacks 2day and endtanks were fine and no cracks in the intercooler itself
Any other ideas of what this could be causing this error code and having no boost at all
thanks again
Old Aug 31, 2012 | 03:49 AM
Soofisahab's Avatar
thanks again
Did you take off the bumper? If not, you cannot rule out the endtanks.
Do a boost leak test.
Old Aug 31, 2012 | 10:39 AM
DPveritasGold's Avatar
^ run the test.
I ran it on mine but I didn't find anything, but a lot of people find out that their end tanks are cracked this way.
Old Aug 31, 2012 | 03:09 PM
Wangspeed's Avatar
You popped a hose off if you're not even getting past 0. A cracked intercooler usually results in some boost. 0 means you cannot build pressure at all. If your intercooler has a MASSIVE hole, then yes, you would end up with 0, but more than likely, it's just a hose. A 10 minute fix.
Old Aug 31, 2012 | 07:21 PM
SSlobalt's Avatar
It'll probably look like this:
Old Sep 1, 2012 | 12:16 PM
jgerma01's Avatar
Problem solved ^ this and replaced MAF sensor
Old Sep 1, 2012 | 12:29 PM
SSlobalt's Avatar
Awesome! Point goes to Wanger.
Old Nov 25, 2013 | 01:46 PM
ROB517's Avatar
I know this is old but I am having a problem similar to it. The only big difference is that it’s been an ongoing problem and I’ve noticed that my car has boost for the first 5 minutes or so then back to zero and doesn’t come back until I start her back up. Do you think it’s a bad MAF?
I’m running k&n sri and catless dp.
Old Nov 25, 2013 | 03:14 PM
05g5's Avatar
your not starting your car up cold and driving it hard/inboost for that first 5 min are you? lol
thats so bad, i dont even drive tc/or sc and i know that
Old Nov 25, 2013 | 03:29 PM
ROB517's Avatar
No after it warms up, I don't even put it in gear when its warming up. I've shut it down at a red light and start it back up.
Old Nov 25, 2013 | 05:28 PM
ROB517's Avatar
Anyone?
Old Nov 25, 2013 | 10:11 PM
TCBalt09's Avatar
Fuel trims are probably off. Get something to read the sensors
Old Nov 27, 2013 | 11:34 AM
penguinguy37's Avatar
I had a very similar thing happen but my boost was cut down to about 3 psi and the car was not in limp mode. Turned out to be the purge solenoid went bad. I hope this helps
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
