What is this part pictured below? It's behind the engine just above the output shaft. I tried to get a look at the top and it doesn't look like oil is coming from above it.
I've looked a good bit from under and above. It looks like a result of PCV escaping the port on the back of the valve cover. I do have the Powell AOS and had to put an NPT fitting in that port for it. There is no shiny wet oily residue anywhere. It's all just that light oil/dirt film on everything below that port. It's such a slow accumulation that it just can't be a leak from where oil actually flows. I hosed it all down with brake cleaner and I'll watch it. This has been going on for a while, it seems.
Did you ever resolve this issue? I'm having the exact same problem with my 09 lnf
