please help P0451- EVAP Emission Control System
Old Jan 3, 2012 | 01:07 PM
ssturbo305's Avatar
please help i got a CEL with this code P0451- EVAP Emission Control System
while i was driving on the highway. what does that mean? car seemed to run perfect even with the code. full boost and everything?
i went to the car and cleared the codes?
is this code a major problem? whats your opponion ?
should i have just cleared it and if it comes up again take it to dealer?
thanks
Old Jan 3, 2012 | 01:54 PM
Dart_SI's Avatar
does youre car start fine after filling up or does it give u a little bit of trouble?
Old Jan 3, 2012 | 05:47 PM
ssturbo305's Avatar
Never given me any of those problems ^^^
Old Jan 3, 2012 | 06:03 PM
09BlueBaltSS's Avatar
Its says "evap emission control system pressure sensor range/performance". Possible bad seal on the gas cap. Check it out.
Old Sep 3, 2012 | 10:47 AM
nutty21's Avatar
Jacking this thread.
I've had the same code. Been throwing parts at it and nothing seems to help.
Fuel Tank Cap - ACDelco GT283
Replaced Valve Assembly - ACDelco 214-1473
Replaced Exhaust Gas Recirculation Valve - ACDelco 214-2230
Could really use some help here.
Thanks,
Jay
Old Sep 3, 2012 | 10:57 AM
nutty21's Avatar
[ECM] P0451 - Evaporative Emission Control System Pressure Sensor Range/Performanc
Old Sep 3, 2012 | 11:20 AM
nutty21's Avatar
Would love some input on this.
I'm thinking of replacing the Fuel Tank Pressure Sensor - ACDelco 13502903 next,
but would love to hear from someone on this...
Old Sep 3, 2012 | 06:46 PM
Stamina's Avatar
There's an evap pressure sensor on the side of the charcoal canister behind the fuel tank. Based on what the code is saying, it would seem that it could be that.
Old Sep 3, 2012 | 09:45 PM
BNRacing's Avatar
I had the same code, replaced the 3 items in post #5 and it fixed it.
Old Sep 4, 2012 | 10:00 AM
nutty21's Avatar
You wouldn't happen to have the part number for this by chance?
Old Sep 4, 2012 | 11:25 AM
Balt_and_Vette's Avatar
You might also have to replace your canister in the back. There is a check valve inside it and it can get gummed up.
Old Sep 4, 2012 | 03:30 PM
Stamina's Avatar
I believe the one I'm thinking of that goes in the side of the canister is the same one you posted up actually. At least it looks to be, based on what I can tell on part diagrams.
Old Sep 5, 2012 | 04:30 AM
nutty21's Avatar
Sounds like this may work then.
Will keep you all posted when the part comes.
Guess this isn't an easy code. Seems there's a lot of things that could possibly be wrong.
Old Sep 9, 2012 | 05:45 PM
sswitnutz's Avatar
This is a sensor located under the hood.. Doesnt cause any change in performance
Old Sep 9, 2012 | 07:21 PM
Stamina's Avatar
That's incorrect. The MAP sensor you're thinking of doesn't have that green rubber seal, has a different part number, and also goes in the IM. This is the fuel tank pressure sensor (also a pressure sensor, like the MAP/TMAP sensors) that connects into the evap charcoal canister (#24 in the diagram).
Old Apr 30, 2014 | 11:51 AM
casasgonzalez6824's Avatar
I recently had this code too! What does the car do when this code?? My car had trouble when I filled up the gas tank & would boost low boost between 6-12psi on each gear ! I went back where I got tuned and he replaced the valve assy in the picture ^ it was boosting really good til 3-4 days later now 1 st gear won't go over 8psi
Old Apr 30, 2014 | 12:18 PM
Sounds like a boost leak, start a new thread in the problems sub-forum (include information about your cobalt and more specifially the issues in a numbered list, it reads easier). This is a 2yr old thread
Old Nov 24, 2014 | 02:15 AM
stevehendo34's Avatar
thanks
Having this code and my car about dies when gas cap off when filling. Runs fine when with cap on. Do you think this is a diagnostic code on the pressure sensor before any evap testing is done by the car. Were is the tank pressure sensor is it under the tank or by charcole canister. Hope I can limp it until spring.
Old Nov 24, 2014 | 09:48 AM
tomj77's Avatar
I didn't have a code but I had issues filling. Pump constantly clicked off when refueling. I changed everything. The canister , purge solinoid, vent solinoid and fuel tank pressure sensor. No issues since.
Old Jan 5, 2017 | 05:26 PM
bahoodle's Avatar
wat was the fix for this code ? is it the pressure sensor purge valve vent valve charcoal cannister or gas cap or hoses lmao
Old Jan 9, 2017 | 08:30 PM
bahoodle's Avatar
i replaced the pressure sensor n it got rid of it for anyone else with this code :P
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ColonelMustard
North Pacific
Sep 29, 2015 03:02 PM
Coballin13
Sep 25, 2015 08:43 AM
