Porous block????
Porous block????
Would porous block instantly dump a full coolant overflow into the oil? Car is a 2008 with 140k. Why would it take so long to happen?
Sorry man. You're in good company. That build date looks to be the tail end of the model year. I think mine's an August date for the following model year. Very likely yours is in the bad batch of blocks. An LDK from zzp won't have that problem.
Because it's fatigue in aluminum. It can happen at any time. There aren't many other options. If it were the oil cooler you'd likely see oil in the coolant rather than vice versa due to pressures, but you could check it.
06noscobaltss
Nov 19, 2006 06:21 PM
