Power loss < 3000rpm?
Old Sep 3, 2009 | 07:20 AM
SSsteve's Avatar
Ok like the title says I am getting a power loss in 1st and 2nd gears but only under 3000rpm. Any ideas? It kinda boggs out on me a little. And then at 3000 it takes off. No codes and no power loss message. Only mod is dejon sri
Old Sep 3, 2009 | 07:34 AM
CudaJoe's Avatar
funny AFRs from the intake maybe?
Old Sep 3, 2009 | 07:47 AM
SSsteve's Avatar
I've had noting but problems from this intake so I wouldn't be suprised. I might put stock back on to see if it corrects itself.
Old Sep 3, 2009 | 07:52 AM
Sweetsandman's Avatar
Step 1: remove shitty intake
Step 2: put stock intake components back on
Step 3: enjoy the power below 3000 rpms
Old Sep 3, 2009 | 08:05 AM
SSsteve's Avatar
LMFAO I'm glad I'm shitting right now otherwise it would hve been in my pants.
Ohh and it is backfireing like a mother
Old Sep 3, 2009 | 08:15 AM
I haven't had that intake...or any for that matter...because it seems that EVERY one that people log data on...it throws the fuel trims off "like a mother." Your car is trying its best to compensate for the weird MAF readings but can't fully do so...so I would suggest that unless you get a tune for that intake...go back to stock
Old Sep 3, 2009 | 07:18 PM
SSsteve's Avatar
Alright now when I start the car it has an extremely rough idol. So I guess chevy gets to take care of it
Old Sep 3, 2009 | 09:14 PM
09BlueBaltSS's Avatar
I assume you went back to stock?? Disconnect the battery and hold the pos and neg battery leads together. This will clear everything the car has learned from trying to correct the maf readings and it will start the learning process over again
Old Sep 3, 2009 | 10:08 PM
BartSS's Avatar
I dunno I guess I'm lucky but I haven't had any issues with my intake and that was my last mod
Old Sep 4, 2009 | 12:29 AM
revhigh18's Avatar
how many miles are on your car?
Old Sep 4, 2009 | 08:56 AM
SSsteve's Avatar
around 16000 miles.
at this point i am thinking that it is the head gasket. it is sputtering A LOT more now and the power loss is almost bringing the engine to a halt. i hope i make it to the dealer on tues. but until then i will try the battery thing.
Old Sep 4, 2009 | 01:20 PM
revhigh18's Avatar
around 16000 miles.
look for a leaking vacuum line or and make sure all your charge piping is all secure and change your spark plugs
Old Sep 10, 2009 | 01:22 PM
SSsteve's Avatar
Good call. Turns out it was a bad hose. Should have the car back later today
Old Sep 10, 2009 | 01:25 PM
pookie025's Avatar
is it saying reduce engine power in the dic
Old Sep 10, 2009 | 02:38 PM
SSsteve's Avatar
No not at all. No codes whatsoever
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
ernnyyes
Oct 2, 2015 05:16 PM
717ssbalt
Oct 2, 2015 04:01 PM
Stuff
Oct 1, 2015 05:47 PM
