Terrible rattle!
Old Sep 9, 2009 | 04:28 PM
RYRO14's Avatar
Terrible rattle!
I have a rattle coming from the back of the car where the child seat connectors are. What is rattling because I have heard about but am not sure what it is.
Old Sep 9, 2009 | 04:36 PM
09turbo's Avatar
whats up dude?
omg thats where the noise in my car is coming from.
i thought it was the metal clips that hold on the rear deck carpet... no
and then i thought it was my retro 3rd brake light...
and it still does is. someone please help us!! lol
Old Sep 9, 2009 | 04:39 PM
brickloaf's Avatar
probably the plastic pieces that cover the metal connectors, but then again the only reason mine did that was cuz of subs
Old Sep 9, 2009 | 04:44 PM
sbdblyss's Avatar
My car rattles back there. My sub has destroyed my glued-together car :-(
Old Sep 9, 2009 | 04:46 PM
1BADSS/SC's Avatar
its ur brain rattling in ur head
Old Sep 9, 2009 | 04:47 PM
09turbo's Avatar
no it cant be. its way to loud to be those. i checked... and cant find aything.
Old Sep 9, 2009 | 05:08 PM
RYRO14's Avatar
Thanks for the input. Casey is yours coming from the same spot?
Old Sep 9, 2009 | 05:15 PM
09turbo's Avatar
yea i had the headrest off and half of the back end of the car taken apart. i though i fixed it, but couldnt find anything... i will try a few more things when its not raining. have you tried anything?
and is it when you hit bumps you can hear it? even little ones?
Old Sep 9, 2009 | 05:20 PM
Mindrot's Avatar
Sub + Plastic = ****
Old Sep 9, 2009 | 05:21 PM
09turbo's Avatar
no, its loud inside the car
Old Sep 9, 2009 | 05:24 PM
Mindrot's Avatar
Like I was saying.. Subwoofers will rattle the entire car. Inside and out. Something could have gotten loose over the years.
Force's Avatar
Check the retaining clips and pivot points for the reat seats... Mine made more of a squeak than a rattle, but a little bit of tape to snug everything together worked wonders.
Old Sep 9, 2009 | 09:40 PM
Highbeamz's Avatar
I found a couple things that rattle in the rear...
1.) The plastic covers that go over the connector whatevers for the rear defroster, they're held on quite loose and can rattle around. I secured them.
2.) The cables that run from the puller to the rear seat latch (for the fold down function) is noisy as all hell. I tried to muffle it by putting door insulation foam stuff in a few places where they could touch the metal frame in the rear.
Old Sep 9, 2009 | 10:27 PM
09turbo's Avatar
i dont play it that loud, and iv only had it a year. got it new.
yea i thought it was something to do with those 2 things. sometimes its like a loud knock even... so idk
Old Sep 10, 2009 | 01:04 AM
Highbeamz's Avatar
I do have a loud knock (which hopefully is being fixed at the dealership like I FREAKING told them to, again!)...it sounds like it *could* be coming from the rear when it happens, but I know it's the door striker or the striker plate...either way if you grab the round piece where the door hinge latches onto and pull hard you can hear a crack sound. It amplifies due to the weight and hollow design of the door.
That said problem only happens over harder bumps or a bump in mid corner.
Just a thought.
Old Sep 10, 2009 | 01:14 AM
09turbo's Avatar
can you post pics of where exactly your talking about? please?
Old Sep 10, 2009 | 01:31 AM
Gimpster's Avatar
The onstar brain is on top of the rear deck, under the cover. Wonder if its possible that is causing any noise. Wouldn't think so, but who knows.
My car is a rattletrap just like every other GM I've owned, turn the radio up and they go away
Old Sep 10, 2009 | 08:54 AM
Force's Avatar
Someone did a how-to on it, here's the link:
https://www.cobaltss.net/forums/show...ar+seat+squeak
Those pictures don't perfectly explain how to get the seats off, so if you have any other questions feel free to PM me.
Old Sep 10, 2009 | 09:06 AM
Black08SSTC's Avatar
Check this ------> https://www.cobaltss.net/forums/show...t=chirp+squeak
my 07 LT had that and it fixed it
Old Sep 10, 2009 | 09:10 AM
Highbeamz's Avatar
Maybe check and make sure your rear seats are fully locked in the up position. Mine came unlocked just slightly and they rattled over every damn bump. Again just a thought...
Old Sep 10, 2009 | 11:21 AM
rukkee's Avatar
Fold down the rear seats and see if it goes away....then you know it's the rear seat latches.
Old Sep 10, 2009 | 02:46 PM
09turbo's Avatar
yea maybe this is the problem. maybe i can get a few of my heafty friends to sit in the back and see if it goes away... lmao
Bluelightning
Nov 11, 2015 02:41 PM
How to Guide
57
Oct 15, 2015 11:56 AM
jimbofug007
Oct 2, 2015 12:06 PM
Jacque8080
Sep 9, 2015 09:21 PM
