Powertrain warranty and your turbo.
Old Jul 15, 2008 | 08:01 PM
80vetteL82's Avatar
Okay, recently I noticed in a thread somebody stated that the turbocharger in our cars are NOT covered under the 5yr./100,000mi warranty, but I cant find the thread. This is incorrect, and I just wanted to correct it. I believe the person said it wasnt because "its not part of the sealed engine." According to GM both turbo and superchargers are covered under the Powertrain warranty:
What does the The Chevy 100,000-Mile Warranty include?
In general, the powertrain warranty covers the engine, transmission, transfer case and axle assemblies on light duty vehicles as indicated below:
  • Engine
    Cylinder head, block, timing gears, timing chain, timing cover, oil pump/oil pump housing, OHC carriers, valve covers, oil pan, seals, gaskets, turbocharger, supercharger and all internal lubricated parts as well as manifolds, flywheel, water pump, harmonic balancer and engine mount. Diesel engine coverage includes the timing belts until the first scheduled maintenance interval.
  • Transmission/Transaxle/Transfer Case
    Case, all internal lubricated parts, torque converter, transfer case, transmission/transaxle mounts, seals, and gaskets.
  • Drive Systems
    Final drive housing, all internal lubricated parts, axle shafts and bearings, constant velocity joints, axle housing, propeller shafts, universal joints, wheel bearings, locking hubs, front differential actuator, supports, front and rear hub bearings, seals and gaskets.
Just wanted to make sure nobody had bad info about their warranties. Of course this information is all easily accessible at chevrolet.com or your warranty panphlet.
Old Jul 15, 2008 | 08:07 PM
RedEcotecSS's Avatar
Good info.
Old Jul 15, 2008 | 08:10 PM
pimpnwink's Avatar
if you notice i believe in that same thread the info you just supplied was posted as well maybe it was a different thread but i have seen that posted before regarding the tc.
Old Jul 15, 2008 | 09:39 PM
80vetteL82's Avatar
like I said, I couldnt find the original thread, so if it was already addressed I did not see it.
Old Jul 16, 2008 | 01:03 PM
Tomtwtwtw's Avatar
I posted it in the other thead, but it's all good. The more this is mentioned, the better. Definitely important that people know what is and is not covered.
Old Jul 16, 2008 | 01:19 PM
elecblue06's Avatar
just sticky it .. good info man
Old Mar 21, 2011 | 10:25 PM
daveyboy's Avatar
So I guess a clutch assembly is not covered since I don't see it in the description. Thanks for the info though!
Old Mar 21, 2011 | 10:34 PM
emiller's Avatar
A clutch is a wear item and typically isn't covered under a warranty.
Old Mar 21, 2011 | 10:45 PM
Fastgti69's Avatar
x2 as well as brakes
Old Mar 21, 2011 | 10:47 PM
MastaShaKe_88's Avatar
if its a newish car, it'll praly be replaced.. but as far as the turbo, there was a guy on here who got his turbo replaced like 5 times...
Old Mar 21, 2011 | 11:50 PM
Nighthawk243's Avatar
Yeah... it is part of the powertrain. I have a friend that just bought a Turbo Baja where the turbo **** on him about 5 hours after he bought it. He's going to take it back to the dealer and use the warranty (3600mi/3mo) that he was given. If the dealer (A shady as hell one) tries to deny him reimbursement on it, he's going to get one of his Lawyer friends to go after him.
Old Mar 22, 2011 | 08:36 AM
BartSS's Avatar
turbo deff covered i just got mine replaced at 38K along with all 4 injectors and the pcv system. They couldnt figure out why my car burned oil at idle and said it was the injectors at first so i laughed but said ok sure yeah ill take new injectors. It was the PCV system all along but then again they said since the turbo was all covered in oil and suck i got a new one. Sorry for the thread jack
Old Mar 22, 2011 | 08:51 AM
jsscooby's Avatar
supposedly the clutch as a 12k warranty unless of course it was abused.
Old Mar 22, 2011 | 09:07 AM
northvibe's Avatar
people need to read the warranty books provided in the car or online when they buy a car..... not saying this is bad to have posted. But I've posted this info numerous times in numerous threads.
Old Mar 22, 2011 | 09:18 AM
outtamymind's Avatar
thats for all wearable items including your breaks but they scrutinize the parts like crazy, either way you nobody should be going through a clutch in 12k
Old Mar 25, 2011 | 05:48 PM
DillySS's Avatar
[LIST][*]Engine
[*]Transmission/Transaxle/Transfer Case
[*]Drive Systems
It doesn't say Intercooler or charge pipes!!! So if you go in with a botched turbo, if they say that they wont cover it becauses of these parts, you can say they have nothing to do with the actual powertrain warranty. :P
Old Mar 25, 2011 | 06:14 PM
ronn's Avatar
Originally Posted by DillySS
[LIST][*]Engine
[*]Drive Systems
Found this on Sky Forum:
Intercooler Warranty - Saturn Sky Forums: Saturn Sky Forum
"talked with the quality guys here at work and according to them the intercooler is covered under the GM Powertrain warranty.
The labor op code is: J5773 - Charge Air Cooler Replacement and is listed as P coverage which is for Powertrain warranty."
Canadia
Oct 6, 2015 10:20 PM
importkiller
Sep 30, 2015 07:18 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
allpro666
Sep 23, 2015 07:47 PM
twilson380
Sep 14, 2015 10:52 AM
