Removing braided line off valve cover?
Old Jun 12, 2011 | 03:03 PM
  #51
Powell Race Parts's Avatar
Originally Posted by Ch1ck3n
Cutting lines in the engine bay = scares the **** out of me. I guess John will be getting my business when it's time to get the vc pc'd haha
I m wit u. GM hate to spend money on stainless braided lines, they did it for a reason. Darn LNF gets hot under hood and stays that way for ever. Found the coil pack individual wires melted together on a car yesterday. Not sure why folks use Injen alloy charge tubes btw what aheat transfer they have.,,,
Old Jun 12, 2011 | 03:59 PM
  #52
seeyaass's Avatar
I think my bpaint should be arriving from gm tomorrow so bi can get this bitch painted!
Old Jun 12, 2011 | 04:22 PM
  #53
09sscalicobalt's Avatar
yea i might wrap my zzp ic pipes in black heat wrap john well see maybe late
Old Jun 13, 2011 | 07:52 PM
  #54
gotboost?17's Avatar
Nothin Stock
so heres the fitting i made
Old Jun 13, 2011 | 07:59 PM
  #55
iboost's Avatar
Ohhhhh I see. Nice
Old Jun 13, 2011 | 08:22 PM
  #56
mongorat427's Avatar
I used a goofy tool I found at advance to remove the line. It cost $8 I beleive its for fuel lines. When you push it into the fitting it depresses the little tabs inside the fitting releasing the braided hose
Old Jun 13, 2011 | 08:30 PM
  #57
Nothin Stock
yeah i couldnt get it in the valve cover quick connect
Old Jun 13, 2011 | 08:40 PM
  #58
bobbyhill31286's Avatar
subd, planning on replacing my vc soon
Old Jun 13, 2011 | 08:41 PM
  #59
iboost's Avatar
that was my issue too...
Old Jun 13, 2011 | 10:04 PM
  #60
Nothin Stock
yeah i dont feel safe cutting it lol
Old Jun 13, 2011 | 10:06 PM
  #61
dont cut it. I got the trick, and send out exhcange pc covers with the line installed. whats not to like about that? and I supply the q-d tool for the other line which is serviceable easily
Old Jun 13, 2011 | 10:16 PM
  #62
Nothin Stock
i would never cut it, i like my setup as it sits
Old Jun 14, 2011 | 10:33 AM
  #63
BYT*SS*TURBO's Avatar
It's a 3/8 Fuel Line Disconnect Tool. The issue is any that I've tried are too thick to remove the 1 line, the other is easy and in the open.
We have this:
Amazon.com: Mastercool (MAS71200) Push-Connect Flaring Tool Set: Home Improvement
To make our own breather lines on our intakes. A lil expensive but it works very well!
Old Jun 14, 2011 | 11:50 AM
  #64
seeyaass's Avatar
Good stuff!
Old Jun 30, 2011 | 11:28 PM
  #65
Miko's Avatar
posted this in the other thread:
So I figured out an easy way to get the hose off! Plastic/Nylon Zip Tie Wraps or whatever you call them! Get some that are medium sized, a few mm thick, cut four, two inch long pieces (do not use the thin tapered starter section of the tie wrap), insert one piece at each locking tab to disengage it, then pull off the connector (a firm tug was required still).
The tie wrap pieces are great because they are very flexible and easy to get into the connector. Just use tie wraps that are thick enough to fully disengage the locking tabs (but not too thick that it jams trying to be inserted) and you are good to go! The hard part was finding where the locking tabs were but I guess you could cut more pieces and jam the connector full if you wanted to make sure you got them.
Here is a picture of how I got the hose off the turbo side just to demonstrate how this works great to get into tight spaces. On the turbo side the fitting completely blocks about a quarter of the connector but I was still able to fit the piece of tie wrap in to disengage the locking tab (The picture only shows one piece of plastic tie but I used four total).
I'm so happy I have my catch can in finally!
Old Jul 1, 2011 | 01:36 AM
  #66
or u can just buy the valve cover from john powell and he gives it to you lol
Old Jul 1, 2011 | 01:57 AM
  #67
cobaltguy889's Avatar
The one that goes to the turbo, once you undo the bolt thats it. Its like a nipple on a piece of metal on the turbo. Once its out ur done with that part. The valve cover to intake line can sometimes be taken off with these...
I believe they are called like fuel line disconnect tools. I had no luck with these. Some people do. I ended up cutting it off and buying a new braided line
This^
It worked on a buddies car. Piece of cake... Maybe I just got lucky?
Old Jul 1, 2011 | 08:24 PM
  #68
sLAsh's Avatar
I don't have a tc so I am just going off the images I see here but these fittings look the same as the fuel lines on my wifes Envoy. I have had difficulty with those plastic style fuel line dissconect tools but there is a metal style that I find to work better. It is a bit thinner than the plasic ones so it might work
better for the lines on your valve covers. I borrowed a snap on one from a frend of mine bit it looked just like this one that is much cheaper.
FUEL LINE DISCONNECT TOOL 3/8,1/2 FORD/GM DIESEL
someone might wnt to try this style and report back as to how it works
Old Jul 1, 2011 | 08:29 PM
  #69
ls1fbody's Avatar
Haz l33t wheelz.
there is no tool that fits the pcv line at the cover that runs to the turbo. Remove the 6 mm bolt at the turbo housing (10 mm socket) to remove the cover with the line attached. The other braided line to the air intake removes with the proper tool.
I have a little trick Devon figured out here, so we can remove the line that is difficult here at the shop, GM call it unserviceable for good reason, no tool will fit.
All our powdercoated LNF covers are supplied here on an exchange basis, with that line attached, and a tool to remove the other line. The way we work we dont charge a core charge, we rely on our customers to return the cover and the tool asap...
I forced that little blue tool you sent with Mikes in there, and made it work lol.
Old Jul 1, 2011 | 08:32 PM
  #70
Nothin Stock
09ss looks good i cheaped out an did my zzp CP red lol
Old Jul 1, 2011 | 08:33 PM
  #71
o good. so my tool comes back broken, and the covers take longer than your brake lines to come back.
o wait.
nothing takes that long like ur brake lines
Old Jul 1, 2011 | 08:34 PM
  #72
ls1fbody's Avatar
Haz l33t wheelz.
Orrrr, you have me to sit on the curb and fight with that little tool until i manage to force it in and make it work...
o wait.
I didn't break it, i promise. And i found your lines, i just need to get tot he post office. :/
Old Jul 1, 2011 | 08:36 PM
  #73
the pcv on an LNF is very well thought out and effective. i dont see the need for a catch can unless u have a built motor.
Old Jul 1, 2011 | 08:43 PM
  #74
lets see. u said that 3 months ago
i beleive u. I promise
Old Jul 1, 2011 | 09:00 PM
  #75
Turbo'dSS's Avatar
Sexy! I will deff. have to get one of these!! ill also be getting a rear sway bar and possibly a tow hook here soon. lol!
