Removing braided line off valve cover?
Old Jul 1, 2011 | 10:47 PM
  #76
Miko's Avatar
the pcv on an LNF is very well thought out and effective. i dont see the need for a catch can unless u have a built motor.
Yeah it was very clean in there when I looked around but I had bought the can already and saw it as a challenge so I did it. Tie wrap trick made it easy. Someday I'll get a PC'd valve cover too, built motor maybe, we'll see if/when ZZP releases their EFR turbo.
Old Jul 1, 2011 | 11:54 PM
  #77
09sscalicobalt's Avatar
mine was clean too but my intake tube had some oil in it
Old Jul 17, 2011 | 03:45 PM
  #78
Ch1ck3n's Avatar
So... I removed the bolt from the turbo, but that little bugger doesn't seem to want to go anywhere, any advice?
Old Jul 17, 2011 | 05:08 PM
  #79
haha you gotta wiggle it out itll pop out you can use a flathead too
Old Jul 18, 2011 | 03:37 PM
  #80
RAIDERNATION 433's Avatar
Originally Posted by iboost
The one that goes to the turbo, once you undo the bolt thats it. Its like a nipple on a piece of metal on the turbo. Once its out ur done with that part. The valve cover to intake line can sometimes be taken off with these...
I believe they are called like fuel line disconnect tools. I had no luck with these. Some people do. I ended up cutting it off and buying a new braided line
DO NOT BUY THIS KIT!!!!!!! it took me for ever with the gray one and then i gave up. Go buy the metal that adjusts sizes. It will save your sanity lol
Old Jul 18, 2011 | 03:45 PM
  #81
PrincessTurbo's Avatar
Yeah the 3/8th's inch fuel line disconnect tool is what you want .. Push it in while pushing the fitting towards the tool and then pull it off.. Wont fit in the turbo line tho.
The valve cover breather hose to the turbo should just be modified using a dremel cutting off the stem about an inch away ( pry off old hose )
That way every time you need to access the valve cover you aren't spending 40 dollars on a hose ...
I was able to get mine of by prying it off the valve cover side and then refitting the tabs and putting it back on..
It's hard tho.
Old Jul 18, 2011 | 05:42 PM
  #82
Ch1ck3n's Avatar
I straight up had to deadlift that **** out of my turbo. Putting it back in was like a ******* glove though
Old Jul 18, 2011 | 07:01 PM
  #83
seeyaass's Avatar
Probably from heating up and cooling down and whatnot.
Old Jul 18, 2011 | 07:51 PM
  #84
gotboost?17's Avatar
Nothin Stock
i put a lil oil around the seal
Old Jul 19, 2011 | 09:02 PM
  #85
Miko's Avatar
I had a really hard time getting mine out. Wiggling and pulling at the same time until it eventually gave. I thought for sure it was caught on something because at first it moved a bit easily, I guess it was the o-ring squirming around. Putting it back in was a bit tricky too.
Old Jul 20, 2011 | 08:51 AM
  #86
NickD's Avatar
So if I as to remove the pcv line and leave the line for the turbo connected, paint my valve cover and then bake in the oven, how high of a temp can that braided line take? I would like to bake it around 550F, I am guessing it won't take more than 250F before damaging the line.
Old Jul 20, 2011 | 09:12 AM
  #87
jbravoxc3's Avatar
sub'd for forture usage haha
Old Nov 29, 2020 | 02:09 PM
  #88
Marc Larbrisseau's Avatar
Hello,
ref item #22 above (pictures with red intakes) I would like to know the part number or where I could get the fitting that is connected to the PCV valve in the pictures above. Or any fitting to convert to a rubber hose please. I understand the side connected to the PCV is a "quick-loK" connection if I am not mistaking. thanks!
paintballerr78
Jul 23, 2012 11:19 AM
xodus
Nov 14, 2010 11:20 AM
importkiller
Jul 21, 2010 07:46 AM
importkiller
12
May 6, 2010 10:31 AM
rm.lydon08
Oct 12, 2009 03:09 AM
