Which tool do I need to remove the valve cover breather lines
Old Jul 18, 2010 | 12:17 PM
importkiller's Avatar
So, Somebody said there is a special tool that I can use to remove these lines. I don't wanna screw **** up but I wanna take the valve cover off to paint it or polish it.
Old Jul 18, 2010 | 12:29 PM
YelloEye's Avatar
Which lines are you referring to?
Old Jul 18, 2010 | 12:30 PM
ecot3c inside's Avatar
I was using the correct torx driver and somehow stripped 1 of my valve cover bolts.... complete b.s I really want to find replacement non torx for it so I can get in and out quick and not worry about stripping. There is no special tool! I just unbolted the rear metal tube and cut the other holder. only sockets.
Old Jul 18, 2010 | 12:33 PM
I am talking about the braided steel lines that run from the vc to the turbo and from the vc to the intake on the lnf vc.
Old Jul 18, 2010 | 12:44 PM
YelloEye's Avatar
OP has an SS/TC man.
I'll go have a look right now.
Just looked, I'm not sure how to get the actual metal tubes out of the valvecover, but to get the line off the intake its just that little white insert has to unclip from the black one, the end that connects to the turbo is just a 10mm hex.
ericgt79's Avatar
its at the autopart store its called a quick disconnect remover .... the braided lines have 4 clips in there and you just take this plastic peice and stick it in the and it pushes those clips off...you can still use the line after you take it off
part is 4 bucks
Old Jul 18, 2010 | 01:51 PM
thanks
Old Jul 18, 2010 | 01:53 PM
ei3dag3's Avatar
part is 4 bucks
when we meet up can you bring yours to show me how to take mine off?
gonna be doing a powdercoat soon.
Old Jul 18, 2010 | 01:57 PM
ItalianJoe1's Avatar
You aren't gonna get the one that goes to the turbo off the valve cover. Just take it off the turbo.
Old Jul 18, 2010 | 04:18 PM
ericgt79's Avatar
ok
uhh i got mine off..
Old Jul 21, 2010 | 07:46 AM
mongorat427's Avatar
They sell them at advance for about 12 bucks. Comes in handy.
Oct 20, 2015 09:56 PM
dennis69
Oct 20, 2015 04:49 PM
Oct 13, 2015 09:32 PM
Trav3480
Oct 1, 2015 08:17 PM
