Resolution to squeaky sunroofs!!!
Any products in particular?
Honestly, about dirt and dust, I'm concerned about it, but not too concerned about the fact that I put grease on the inside of the sunroof opening. Worst case scenario, if there's grime, etc. I wipe it all out and reapply.
No worries!
Last edited by wantedSS/TC; May 19, 2009 at 11:16 AM. Reason: Automerged Doublepost
I also clean the inside tracks of the sunroof too!
In my 89 Saab 9000 turbo, the previous owner NEVER cleaned the track (I didn't know as it was my first car) and when I stopped hard one day when it was raining water came rushing in on me. I was shocked as hell and frightened as I didn't expect to get soaked!
There's a GM grease for door seals, convertible seals, and window seals.
Then there's 303 Aerospace protectant. You apply it and wipe the excess off. It dries off very rapidly but is approved for a wide variety of rubber products even aircraft door seals.
Silicone grease and other grease products that remain "jelly-like" can attract dust/grit. When you trap this grit between the window seal and roof, it can wear out the paint.
Maybe someone already said this, but read the manual?
It says in the manual that you should periodically put silicone based lubricant on all of the seals. It also said something about avoiding petroleum based lubricants if I remember right. I don't have my car with me right now but it's in there.
exactly what i was thinking. and right out of the manual
Weatherstrip Conditioniing Weather strip lubercant, Superlube GM part # U.S 3634770 Canada 10953518 or Dielectirc sillicone grease GM part # US 12345579 canada 992887
That is 100% correct: use silicone grease on rubber seals
