safe range
Old Dec 29, 2012 | 01:39 PM
TY8425's Avatar
safe range
ok i think ive submitted this thread before but just in case ill ask again...
i have an internally stock lnf and im curious to find out, with a very good tune, stock turbo, and a list of bolt ons, whats the max recommended safe boost range i can run without messing anything up internally? and to answer the next question, yes, i do intend to do a turbo upgrade fairly soon. but for now, just checking on safe internal range. i heard it was 30-33 psi but not sure
Old Dec 29, 2012 | 02:04 PM
kzak104's Avatar
30psi? Your definitely going to kill your stock turbo at 30psi. I'd say safe is around 22psi. After around 24 all the stock turbo does is produce a **** tone of heat.
Old Dec 29, 2012 | 02:47 PM
Nfamous60's Avatar
curious on where u here 30psi from, but most will say 22-24, myself i have pushed 27 for bout 5months.
Old Dec 29, 2012 | 03:03 PM
kzak104's Avatar
and your sig says rebuilding lol
Old Dec 29, 2012 | 03:59 PM
TY8425's Avatar
lol like i said the turbo im not worried about. its the motor. how much boost can the stock motor take before **** starts to go?
Old Dec 29, 2012 | 04:19 PM
kzak104's Avatar
"h a very good tune, stock turbo, and a list of bolt ons"
? 24 psi max, after that ur pumping heat into the engine.
Old Dec 29, 2012 | 04:21 PM
kzak104's Avatar
"a very good tune, stock turbo, and a list of bolt ons"
? 24 psi max on stock turbo, after that ur pumping heat into the engine. i think stock engine is good tille 350-400 "safely" but you can run less boost with a big turbo to get more power. so i think its more whp you need to worry about not boost,
searching around people seem to say 30psi stock bolts head gasket and internals.
Old Dec 30, 2012 | 12:07 AM
Nfamous60's Avatar
LOL you got me there but in el paso it was cool for me to run 27psi, when i drove home on leave i had a 31psi spike and think that was to much, she started pouring our white smoke everywhere, she wouldnt build boost but when i play with the pedal she would build boost again, so full rebuild has been taken place for bout 8 months now just need my block and stage 2 trans.
Old Dec 30, 2012 | 12:13 AM
dakotaspeir's Avatar
#cobalthoes
23psi is perfect
agentirons
Oct 16, 2015 02:11 AM
Oct 13, 2015 09:32 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
Rduncanss06
Sep 27, 2015 11:17 PM
