SS/TC Ready For Winter
LOL... the caliper will make its own grove in the rim so it wont be a problem for long. I guarrentee someone has done it!
so in short, if i got these for an 08 ss/tc they will fit? im fine with running a 3mm spacer if i have to
http://www.tirerack.com/wheels/Wheel...XL&qty_front=4
I'm going to mod it a bit, if I get crazy I'll drop you a line, can't wait to see what you guys do with the new car!
Continue until you've relearned all the corners. This process takes 3-5 minutes tops.
The car has a built-in TPMS re-learn. If I remember correctly, you turn the key to "ACC" and then hold down the lock/unlock buttons on your remote fob. The car should honk and begin flashing one of your turn signals. Go to the corner where the signal is flashing and let air out of the tire until the car beeps at you again, then fill the tire back up. The next signal will then light up.
I just let the air out of each until complete, then refill 'em all. The turn signal stays on bright for the corner to relearn, not flash. Never timed out doing it that way.
I'm just going off memory, I only had to do this once. Either way, it takes very little time and it's braindead to do.
So is the best thing to do is to over fill the tires to say 40lbs and then let air out one at a time until everything is reset right? Then readjust to correct pressure?
No no, just go to a gas station with an air pump (preferably a free one) if you don't have your own compressor. Use a manual pressure gauge to let air out of the tires to do the process and then fill them back up on the spot. There isn't really a reason to over-inflate them beforehand... You're not letting out a ton of air here, so they won't go anywhere NEAR flat.
Winter ready with great reluctance...bought my Cobalt for DD but never intended to fall in <3 with this car...now it's too late so the least I can do is do winter in style...
18" DR33 mounted with 225 Hancook Spicy Spicy Squid...I mean Icebear...need to find a salt car for next year...
Thanks Force for the info...TPMS all reset and good to go!
These winter compound are sure soft...even with 18's the sidewalls sure feel squirmy...going to up the pressure to 38 all around and see if that feels better...
She says yes but only if you kiss her first...
Yup...love those...
Yup...love those...
Iceberg
Sep 29, 2015 12:33 PM
