stiff steering
Old Feb 21, 2018 | 08:04 PM
unforgiven's Avatar
stiff steering
the steering on my 09 ss has been getting stiff lately like not returning to center when turning but only seems to be stiff while driving it behaves normally when not moving but get stiffer as speed increases i'm thinking maybe the EPS is acting up and i'm not sure if it had the recall work done, has anyone else had an issue like this?
Old Feb 21, 2018 | 09:08 PM
Solaris99's Avatar
Check for play in the steering rack. I started getting difficult steering when my rack began to fail.
Old Feb 22, 2018 | 09:31 AM
jdbaugh1's Avatar
If it behaves normally when not moving and gets stiffer while driving I would definitely say it is your EPS like you guessed as it is designed to modulate the amount of steering assist according to speed.
Old Feb 22, 2018 | 04:07 PM
cluelessk's Avatar
Mine has randomly stopped working a few times. Been fine for a long time now.
Old Feb 23, 2018 | 09:26 AM
ProfDNS's Avatar
Mine started squeaking, so I hit that **** with WD-40. No more problems.
Old Feb 23, 2018 | 04:24 PM
jdbaugh1's Avatar
WD-40 is no bueno for a lubricant
Old Feb 23, 2018 | 10:59 PM
ProfDNS's Avatar
Probably, but the silicon stuff should last. I mean, it's been like... 6-7 months now since I had any issues. I did the same to my sunroof and has been bueno.
Old Feb 24, 2018 | 08:22 AM
jdbaugh1's Avatar
Yeah but the silicon is just WD branded silicon not actual WD-40. I thought you meant regular old WD-40
Old Feb 24, 2018 | 09:55 AM
ProfDNS's Avatar
Ah no, my bad. Regular oil WD-40 is great for small engines and hinges and ****, but you're correct that it should not be used on cars for these types of scenarios
Old Feb 24, 2018 | 12:42 PM
63 Nova SS's Avatar
Could also be that the shaft from the column to the rack is going bad also. There is an updated design for it as the factory shaft is prone to failure.
GregC
Canadian Mid East
Apr 23, 2014 12:59 AM
DWoods54
Jan 18, 2014 11:36 PM
sugardaddy2885
How to Guide
31
Dec 19, 2008 05:09 PM
bl0wnbalt
Sep 8, 2007 09:18 PM
memphisr24
Jun 4, 2007 04:12 PM
