stiff mounts cause cel
Old Sep 8, 2007 | 01:52 PM
bl0wnbalt's Avatar
I've been getting this cel for the past few days, P0300, a missfire code, I was also getting P0315, a crank sensor code, well I took it into service thinking my crank sensor was bad and causing the missfire code
Well the tech diagnosed my car, the sensor is still good and there is absolutley no missfire, he showed me this all on the tech 2, he's saying my TD and tranny mounts aren't allowing the engine to flex like it would with stock ones and its causing my sensors to give false readings
Is anyone else having, had or heard of this theory?
Old Sep 8, 2007 | 01:53 PM
joeworkstoohard's Avatar
new onw by me, man.
i suppose it could cause it to jitter.... how hard are these mounts? and which model balt is it?
edit: just read what section we are in.
Old Sep 8, 2007 | 01:56 PM
HackAbuse's Avatar
Yes its common. The knock sensor is basically a sensor that picks up certain vibrations, by using solid mounts, the engine vibrates more to the point where the sensor is picking up false knock.
I'm sure there is a way to tune it so it stops, but you'll have to ask the tuners how they do it.
Area47 might know
Old Sep 8, 2007 | 01:59 PM
bl0wnbalt's Avatar
I figured I would need a tune to fix it
Old Sep 8, 2007 | 06:20 PM
SSdan's Avatar
Try taking it out and seeing if the CEL still comes. If it does, then the problem IS the sensor.
When I had my mount in I had zero issues besides the insane amount of vibrations. I decided **** this and upgraded to stock
Old Sep 8, 2007 | 09:18 PM
bl0wnbalt's Avatar
ive been running my td for a year and my prothane tranny bushings for a month with no issues, after i left the dealer today, the car ran fine, than my ******* gauges all went to zero except my boost gauge, the screen read "power steering" and its been doing that off and on about 3 times tonight, only happens when im driving at like 20 or slower
turbochargedss2012
Sep 20, 2023 12:17 PM
OrangeCoba
Oct 1, 2015 10:00 PM
n20saturn
Sep 30, 2015 12:26 AM
DocSvensk
Sep 27, 2015 02:24 PM
