stock turbo
I hate to say it, but use the search feature man.
The stock turbo is a Borg Warner K04 and its good for up to 22-23psi, and with a good tune that would get you as much as 360whp with the right bolt ons from what I've seen.
Trim...
we aren't neons.... it's ******* small!
if I had to guess.... 30 trim if you are going by size...
22-23psi is it's money range... anymore you get a super peakie torque rating and hp that falls on it's face faster than a ***** in an orgy!
good for about 350-360whp or so.... 370-380wtq at like 3000rpms.
Trim...
Our stock turbo has a 43mm inducer on the compressor. The exducer is 59.5. this gives this turbo a trim of 52. The wheel has the same design as the popular extended tip turbos being used by a lot of racers. Unfortunately, it is just too small to support a lot of power.
As far as power potential for this turbo, it will not support 360whp on a stock 2.0. Expect numbers more like 330-340 with full bolt ons and a good tune. At that point, the turbo is just plain done. Torque on the other hand can be pushed past 400 pretty easily by pushing 30+ psi at 4000 RPM.
I don't think you have a firm grasp on how the trim is calculated. Just because a turbo is small doesn't mean the trim is low. A 40mm turbo could be a 60 trim. Just the same, a 90mm turbo can be a 40 trim.
information like this should be a paid service.
He got owned
I don't think you have a firm grasp on that I was making a joke...
I know the trims on turbo's are based on wheel sizes...
I was messing with him because the whole "turbo" community feels trim means it's bigger or smaller in over all size... hence why I said if based on size in my post.
kthxbai
I would just recommend going with a catless dp and then a tune and leave it like that cause your tune is gonna be the most gain in hp
Tune + catless will be the biggest gain in power...stock intake and exhaust (cat excluded) are very efficient for just about anything the stock turbo can produce. Everyone follows a different path, but I think most will agree that the first step in getting good power is to up the boost and ditch the cat.
I wasn't trying to to be a powner. It's just a common misconception that trim tells the size of the turbo. If anything, it can help determine the pressure ratios it will perform best at. Of course you wouldn't get far without flow data or a compressor map anyway.
I know you werent, I'm just saying you put his "thoughts" sorta speak to rest when you said that
Not really bud....
My thoughts were what I meant... as a joke... WOW... I've been around quite awhile junior...
I was speaking ricer math as 90% of this site thinks the trim has to do with overall size....
kthxbai
kthxbai
its clear that sarcasm on the internet doesnt go over well
Trim...
how could the sarcasm not be picked up....
