suspension clunk.
Old Jun 21, 2012 | 10:21 PM
nhanson's Avatar
Originally Posted by 09TcSedan
what the hell? i check the websites and it didnt say nothing about moog.
i may just order them from oriley,i can get a 20% discount
Im going to get my strut mounts from them...$42 for 2 of them
Old Jun 22, 2012 | 01:22 AM
CaptainShortbus's Avatar
My favorite way of checking stabilizer bar links is to grab a buddy, and grab hold of the link while they bounce the car up + down.
Old Jun 25, 2012 | 02:04 PM
09TcSedan's Avatar
Going to my buddy's house today. We are going to check the and links and bushings. God I hope it's an easy simple fix
Old Jun 25, 2012 | 02:16 PM
nobody2u's Avatar
End links are simple. Just pull on them. I'm literally replacing mine tonight cause they went. Then putting new springs on after that.
Old Jun 25, 2012 | 02:21 PM
09TcSedan's Avatar
I'm hoping it is the end links. The local auto store has them in stock
Old Jun 25, 2012 | 02:30 PM
nobody2u's Avatar
Literally just tug it back and forth while your wheel is on. If it makes the same noise that's what it is. You won't be able to hear it if the wheel is jacked up. At least not on mine.
Old Jun 25, 2012 | 02:37 PM
09TcSedan's Avatar
Tug on the endlink itself?
Not really that familiar with suspension. My buddy who is helping me knows more.
Old Jun 25, 2012 | 02:51 PM
Staged07SS's Avatar
Administrator
Administrator
Yep, and tug on the sway bar as well.
Old Jun 25, 2012 | 08:41 PM
09TcSedan's Avatar
Well i gave it a few tugs. No noise what so ever. Dammit
This is driving me nuts. Its not a super loud clunk but when im in traffic and creeping doin about 10mph i can here the sound, im in the fast lane and the sound bounces off the median.
edit: well,i gave it another go. tugged,pulled,pushed and nothing! i have to bring my car to the dealership for the key ignition to get replaced. i may just have them look and see if they can figure out what it is and if it is something simple,i will replace it.
Old Jul 17, 2012 | 06:12 PM
dskav's Avatar
i'm having the same issue, going to try the moog endlinks. should i be going for the 9.86" long ones or the 11.8"? my car is a 2.2 that i will be putting FE5 shocks/struts on with Pedders
Old Jul 17, 2012 | 07:56 PM
  #36
nhanson's Avatar
Get the longer ones...i have the shorter ones and my sway bar clunks over bumps on something now
Old Jul 18, 2012 | 07:19 AM
  #37
Staged07SS's Avatar
Administrator
Administrator
If you are going to install the FE5 suspension you will want the FE5 Moog Endlinks.
No.
You have the FE3 suspension which requires the longer endlinks (unless you modfied your suspension?).
If it is clunking, check to make sure the bolts are torqued to spec (55 ft-lbs.)
Old Jul 18, 2012 | 01:17 PM
  #38
dskav's Avatar
sorry but not sure which are the FE5's. I was looking at ZZP and they simply have the two different lengths, I don't see anywhere differentiating between FE1/3/5. is the shorter one for the FE5 suspension? thanks for your help
Moog - MOOG Front Sway Bar End Link #MOOG-K750012
Old Jul 18, 2012 | 01:28 PM
  #39
Staged07SS's Avatar
Administrator
Administrator
The shorter ones are the FE5 links.
Again, ZZP should not have them listed under one part number.
The FE5 part number is MOOG-K750012.
The FE1/FE3 has a different part number.
It can confuse some people.
Old Jul 18, 2012 | 01:33 PM
  #40
dskav's Avatar
awesome, thanks for clearing that up. i'm assuming then that i should be swapping out the FE1 links for those then even if they're not busted (ie source of the clunking) to match the new FE5 setup right?
Old Jul 18, 2012 | 01:36 PM
  #41
Staged07SS's Avatar
Administrator
Administrator
Yea, if you are going to be using an FE5 suspension def pick up the FE5 endlinks.
Old Jul 18, 2012 | 02:23 PM
  #42
dskav's Avatar
placing the order right now, thanks for the help dude
Old Jul 18, 2012 | 02:51 PM
  #43
Staged07SS's Avatar
Administrator
Administrator
No problem man.
If you need any help with the install hit me up.
Old Jul 30, 2012 | 06:37 PM
  #44
dskav's Avatar
just an update, installed the new links along with the rest of the FE5/pedders setup this weekend and all went well. haven't driven it much since the install but so far there has been no more clunking (knock on wood)
Old Jul 31, 2012 | 07:10 AM
  #45
Staged07SS's Avatar
Administrator
Administrator
Nice!
Good to hear.
Old Jul 31, 2012 | 06:18 PM
  #46
dskav's Avatar
ps many people have had trouble getting the nuts off of the link bolts, but with an impact driver it's a piece of cake. bought an electric one for the suspension job and IMO it paid for itself already with how much time and effort it saved me. worth it!!!
Jan 12, 2016 12:01 AM
OrangeCoba
Oct 1, 2015 10:00 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Sep 27, 2015 08:53 PM
