Turbo not working at times, Excessive oil cunsumption at times
Old Dec 27, 2017 | 01:48 PM
fast99cam's Avatar
I have a 2010 SS 2.0L turbo, manual trans, 169k miles and are basically having two issues that I need some direction on. First, when I start (or restart) engine, the turbo will be fine the first time at hard acceleration, if I really get on it, it works fine. Once I let off of the gas pedal, any other times, I get no boost at all. If I turn the key off, then accelerate hard, it has boost, but again, once I back off, I have no boost.
The second issue just happens occasionally. I can go days or weeks without it happening, but sometimes it happens all the time. It is while at cruising speeds, (50-60mph) all of a sudden, I hear detonation, look back and the smoke is so bad, I cant even see a car behind me. I can stop after a short while, and have had to put in as much as 3.5 quarts of oil. I literally checked it right before the last time this happened, oil level was full, I went about 5 miles with it smoking and used 3.5 quarts of oil. I was out of town on a trip last week and I had this happen 4-5 times on my trip home, ended up consuming 10+ quarts of oil on a 300 mile trip. This also happened about 6 months ago, then all of a sudden, stopped. I have put about 20k miles on it without incident, then last week, started happening again. I unhooked the pcv valve that leads to the intake tube, it helped some but it did not solve the issue. Any help or direction would be appreciated. Like I said, it does not happen all the time, so it leads me to believe its not the turbo but some other ancillary part or valve or solenoid going bad, clogged, etc. Thanks
soaxin
Feb 6, 2014 06:14 PM
CurrentlyPissed
Feb 20, 2011 09:36 PM
Do_WorkSS
May 18, 2010 12:37 AM
mkulrey13
Jan 8, 2007 08:45 PM
2006ArrivalBlueSS
Jun 1, 2006 08:15 AM
