wtf car wont turn offf
Old Apr 20, 2010 | 10:57 PM
yamaha288's Avatar
I got home today same routine pull the e-brake and half way out the door the key wont turn back to the off position. So I sit back in and its stuck wont turn back wiggle it nothing so I drive up to the dealership and the tech looks at it and says he doesnt know. The service writer says that they cant get to it today b/c it is 5:15 to bring it in tomorrow. So I said what am I suppose to do the car wont turn off and the tech says to pull the fuse and disconect the battery.
I have to drive to work tomorrow and do that whole procedure wtf taking it in tomorrow to see what they will do and if they cant fix im going to make them give me a rental this is rediculous
Old Apr 20, 2010 | 11:00 PM
mikeyc1227's Avatar
Stall it out in first while stopped.
Old Apr 20, 2010 | 11:02 PM
Spins All Day's Avatar
Agreed ^^^^ Just make sure you are not parked close to cars while you stall it.
Old Apr 20, 2010 | 11:05 PM
yamaha288's Avatar
^^^ wont the batterey go dead with the key on?
Old Apr 20, 2010 | 11:09 PM
CobaltVenomSS's Avatar
stall it going up a hill... then park it...then wake up in morning and pop clutch in reverse lol
Old Apr 20, 2010 | 11:20 PM
dncalvillo2's Avatar
no joke...had this problem like a week ago. first i would pull the 2 fuel fuses but then I jus stalled it, way easier, then unpluged the battery. its a pretty common thing to happen. i jus took mine to the dealer and they replaced it under warranty but they wouldnt give me a rental so if they give you one ask for a camaro and let me know how it goes hahahahaha.
Old Apr 20, 2010 | 11:23 PM
juice3's Avatar
What causes this problem tho?
Old Apr 20, 2010 | 11:26 PM
yamaha288's Avatar
you live in texas and know that is not possible lol
Old Apr 20, 2010 | 11:27 PM
they told me that it was some electrical problem but they only replaced the ignition cylinder.
Old Apr 21, 2010 | 12:22 AM
Stamina's Avatar
"Come back tomorrow?... The car won't turn off!" LOL
Yeah the ignition probably broke. I've heard of a few other cases where it happened. Sometimes in the auto transmission 'balts, it was a case of the tranny wasn't allowing the key to be taken out since it didn't think it was in neutral or park.
Old Apr 21, 2010 | 01:08 AM
cmatthewb101's Avatar
Arn't there a bunch of threads about this already?
Old Apr 21, 2010 | 01:16 AM
~Mike~'s Avatar
Sounds to me like the key pins are stuck/broken and the ignition cylinder itself isn't recognizing that as the correct key. Kinda like tryin to use your car key to get in ur house...unless ur front door is a door off a cobalt lol
In any event, the cylinder is fucked and they gotta tear apart the plastics around the steering column and replace it. This in no way could be an electrical problem tho if the cylinder isn't turning in any direction
Old Apr 21, 2010 | 02:44 PM
slowbalt84's Avatar
1) Go WOT and reach top speed
2) Jump out of car
3) watch car go into river
4) Sue GM
Old Apr 21, 2010 | 02:56 PM
blackbolt89's Avatar
2) Jump out of car
4) Sue GM
win!
and to OP the battery won't die if you disconnect it as said previously.
Old Apr 21, 2010 | 03:16 PM
slapbetcommissioner's Avatar
2) Jump out of car
4) Sue GM
lol, i like it. might be better if you drive through there garage because the car wouldnt turn off. say it wouldnt go into park either lol
Old Apr 21, 2010 | 04:21 PM
yamaha288's Avatar
^^^this is a win especialy in a manual lol
Old Apr 21, 2010 | 04:24 PM
Shez's Avatar
Same **** happened to mine except my car was off. They key wouldn't move at all. I could take it in and out but it just wouldn't move. Had to get it towed to a dealer and they replaced the ignition cylinder.
Old Apr 21, 2010 | 06:50 PM
yamaha288's Avatar
Just got back from the dealership they had the ignition in stock just had to build it to the key only took about a hour and a half from the time I got there.
Old Apr 21, 2010 | 09:47 PM
08inBama's Avatar
that might be the quote of the year...... since all '08+ SS's are manual
Old Apr 21, 2010 | 10:07 PM
LS2SS's Avatar
2) Jump out of car
4) Sue GM
Isnt that what a guy in a Bugatti did a copuple months ago? theres even a video of it but i forgot where it was
Old Apr 22, 2010 | 12:02 AM
yamaha288's Avatar
^^^ yeah a random guy was videoing it on his phone cuz it was a bugatti and splash there goes the car in the gulf it happened in galveston lol
Old Apr 22, 2010 | 08:20 AM
Shez's Avatar
Wtf! You're lucky as hell. I got mine towed to my dealer the Thursday before Easter and didn't get it back until the next Wednesday.
Glad everything worked out for you though.
Old Apr 22, 2010 | 10:42 PM
army_greywolf's Avatar
To the OP and the rest with the problem. Your ignition has to be cut to your key that's why it takes several days to get it. I'm not gonna quote the guy who said it but they are exactly right the problem is the tumbler mechanism itself, the pin breaks off thus the ignition will not allow the key to be removed since it wont rotate.
I used a classic method that I was actually hoping wouldn't work so easily but it did. I bumped the key while under tension to get it out. It turned after a couple tries, repeated this the next morning to get it to the dealer, I figured I could avoid possible electrical system damage if I could get it to turn. I did NOT remove the key (don't or this wont work to repeat the process).
If your not sure what I'm talking about and you google it to figure it out don't even attempt it. Feel free to disconnect your battery after stalling the car...why not, GM will fix it right? I just didn't want the hassle or the possibility of an ongoing problem.
Old Apr 23, 2010 | 03:13 AM
Touché, i guess this under the lnf section. Just assumed this only happened on the autos.. Boss had same problem but with a 2.4 auto.. But yeah Im fully aware all lnf Balts are manual. Lol
vjoel2011
Oct 2, 2015 12:11 PM
Wind
Sep 11, 2015 06:57 PM
ATOMbomb
Sep 11, 2015 10:48 AM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
