$600 and you can fix the fuel problem?!?!?!
Old Sep 27, 2010 | 12:45 PM
cardelino18's Avatar
this says its Universal and its only a fuel/ignition controller that works parallel to the stock ECU... what do you guys think???
AEM Fuel / Ignition Controller FIC- TREADSTONE PERFORMANCE
Old Sep 27, 2010 | 12:52 PM
ecot3c inside's Avatar
I really don't think it's worth it. Retarding and advancing timing on the fly? I'm guessing you will probably be disappointed if you get it, and if you don't you will be a richer man!
Old Sep 27, 2010 | 12:55 PM
umrdyldo's Avatar
I really think this going to be a waste of time and lots of headaches.
What are you trying to do? 400whp or 500 or what?
Old Sep 27, 2010 | 12:56 PM
redcomet303's Avatar
cardelino18.
I don't think that will work. It "intercepts" the injector signal and alters it.
I believe our injectors are 24VDC where as normal injectors are 12VDC. I also believe ours require more amperage as well.
If you want to control fuel talk with Vince at Trifecta he was able to unlock our ECM's fuel tables. He was able to increase the fuel pressure. More pressure equals more fuel. Also we have a very limited window of fuel delivery.
Old Sep 27, 2010 | 01:01 PM
yes i know about vince...
i just got in contact with AEM and they havent tested it on the DI motors... im not getting it but i was just wondering if this would be another route...but i guess is not lol
Old Sep 27, 2010 | 01:07 PM
09CobaltSS1's Avatar
Originally Posted by redcomet303
cardelino18.
Our injectors are definitely not 24v. Plus the bigger fueling issues here are the mechanical high pressure pump, and the actual size of the injector being maxed. A piggy back system will unfortunately fix neither
Old Sep 27, 2010 | 01:25 PM
pantherqs's Avatar
If you're that desperate for fuel go with AIC1 Additional Injector Controller , same **** but rebranded that Hahn uses for their portfueler setup. I'm probably going to end up going with that sometime early next year. Only around 280$ depending on where you get it from, but you gotta add injectors, rail, and some custom fab cost to it. It's sort of shitting on the whole DI thing, but hey, doesn't seem like we got much choice atm.
Old Sep 27, 2010 | 03:09 PM
If you want to move to port injection I don't think it would be that hard. We can just drill our intake for the injectors and then put plugs where the DI injectors are but we would need to run LSJ pistons. As for the ECM have you heard of Megasquirt? its a stand alone ECM that can be had for about 300 dollars. We already have an intank fuel pump so it would really just be pistons and installing normal injectors. It would probably run like crap though because the head is made for DI. best to just use the head from the LSJ too. but at that point wouldn't it be better off to start with a cobalt/sc?
turbochargedss2012
Sep 20, 2023 12:17 PM
no_ss
Oct 18, 2015 11:58 PM
dieGone
Oct 1, 2015 06:27 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
