08 ss turbo, major problems!!
Old Dec 17, 2012 | 11:30 PM
bjohnson991's Avatar
okay first off ill name the mods then tell you the situation..
zzp upper ic pipe with zzp bov
zzp lower ic pipe with maf relocate
zzp intake with stock air box
zzp 3" catted dp with 3" exhaust no res or muffler
zzp tune
now i just had the lower ic pipe put on 2 weeks ago, everything has been running fine, this last weekend i drove about 160 miles round trip with no problem, last night i drove down to the store and it jerks real bad when i tried to use boost, now a cel light came on tonight on my way home, wont accelerate, backfires, rough idle. its not a blown turbo because i can still hear it spool up when i try to take off, sounds like before the problems started. tried checking the ic pipes and all the couplers but could see the ones that connect into the intercooler, it was dark out and freezing cold, light on my flashlight was dieing so i didnt get into checking it much. any ideas on what the problem could be?? if you need more info let me know or questions.
Old Dec 17, 2012 | 11:45 PM
definately go to autozone to get your codes read asap. kind of the best starting point for a situation with a CEL
Old Dec 17, 2012 | 11:53 PM
user 72239's Avatar
check your codes first.
Old Dec 17, 2012 | 11:56 PM
Frogstofall's Avatar
Boost leak. Check for busted I/C and loose clamps. Report back with codes as well like already stated.
Old Dec 18, 2012 | 12:06 AM
SunburstSS's Avatar
So Before You installed the Lower Pipe your MAF was in the intake ? and now you installed the Lower IC Pipe and put the MAF there ?
Are you tuned for the BOV with the MAF being located in the lower pipe or the intake still...
Old Dec 18, 2012 | 12:12 AM
willdrew's Avatar
try all the above. if it was running fine before and just started doing this could be bad gas also
Old Dec 18, 2012 | 01:59 AM
yea i had everything tunned for what needed to be, having the bov required a retune and having the map relocate needed one also, i live mabey 25 miles from zzp so thats where i get all my work done, as for the gas i put 93 in it, i was looking at my slip and it says 93, im not sure if that makes it worse or if it affects anything at all. i had the intake, upper pipe, and exhaust components along with the first tune all done at the same time, the second time there i had the lower ic pipe installed with a retune. do most chevy dealers carry a map sensor?? or would they have to order one.
Old Dec 18, 2012 | 02:01 AM
and yea, the map was on the intake tube, but running the bov caused it to jerk when i let off the gas becasue the bov would go off and the sensor reads all the air went missing so it floods the engine with gas, but having the lower pipe and map relocate solved that problem.
Old Dec 18, 2012 | 03:02 AM
Silverbullet33's Avatar
no codes, no help. def need to look at them to help direct you what/where to look buds
Old Dec 18, 2012 | 08:33 AM
tomj77's Avatar
Shoulda just got that new trifecta tune, no need to relocate maf
Old Dec 18, 2012 | 09:19 AM
prevsrt4owner's Avatar
NEED THE CEL CODE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! The second-guessing will cease.
Old Dec 18, 2012 | 09:28 AM
C_A_D88's Avatar
Intake valves need to be cleaned or replaced
Old Dec 18, 2012 | 10:26 AM
T-Man's Avatar
Bubble gum in the muffler
Seriously though, scan the codes and post them up. Can't help you without that info. Everyone is just guessing at this point.
Old Dec 18, 2012 | 11:16 AM
mightymouse1975's Avatar
not a slam on zzp,but that's where i would start. if your car was fine prior to them working on it,then they should be able to tell you what's going on. i wouldn't touch the car. i'm sure zzp can fix the problem.
Old Dec 18, 2012 | 11:21 AM
rcarr0327's Avatar
if you relocated the maf and didnt get a tune then thats probably the issue.
Old Dec 18, 2012 | 11:31 AM
ctn2mb's Avatar
My car is currently at zzp why don't you have them look at it lol
Old Dec 18, 2012 | 12:40 PM
MastaShaKe_88's Avatar
check your connections, you praly got a boost leak somewhere at one of your coupler connections
Old Dec 18, 2012 | 12:50 PM
Hey sorry for not replying, I've been at autozone getting the codes read, looking at everything and driving back to zzp.. Anyway codes p2195 heated oxygen sensor, p2261 bypass valve stuck, and p0103 map or maf sensor condition
Old Dec 18, 2012 | 12:52 PM
I got a retune with every part I put on so I would have problems, I'm at zzp now so ill give you guys an update shortly..
Old Dec 18, 2012 | 01:22 PM
T-Man's Avatar
Glad to hear it man. Good luck with everything.
Old Dec 18, 2012 | 03:57 PM
Well apparently it's just water in the inter cooler pipes, just a drop on the map sensor is all it takes.. Unplugged it and ran it at higher then normal speeds to flush the water out. Runs fine now
Old Dec 18, 2012 | 06:35 PM
nhanson's Avatar
Water will do that. I have trouble with my ZZP 3" CAI getting water sucked in.
Makes the car think it has a SUPER amount of airflow when it actually doesnt so it floods in the fuel.
Old Dec 18, 2012 | 09:35 PM
yea, after i unplugged the map sensor and now it runs fine. but i dont have the cai, i dont have one for that exact reason. i have just the stock air box with the larger zzp intake tube
Old Dec 18, 2012 | 09:53 PM
T-Man's Avatar
Smart man. Glad you got things straightened out.
turbochargedss2012
Sep 20, 2023 12:17 PM
patooyee
Oct 15, 2015 05:11 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
