300+ WHP Cobalts ENTER HERE (Tire Q&A)
Old Dec 9, 2009 | 10:39 AM
glhs379's Avatar
i run bfg's, see sig
they hook ok from a 2nd hit depending on surface and temp
Old Dec 9, 2009 | 01:37 PM
philip420's Avatar
BFG G-Force hook up nice
Old Dec 9, 2009 | 02:00 PM
glhs379's Avatar
i think the bfg will wear better on the street,
but i believe the et street radials hook better.
Old Dec 9, 2009 | 06:32 PM
Spins All Day's Avatar
Originally Posted by Terminator2
You do know that Toyo owns Nitto right? NT-01 is great for the road course or autocross. NT05 is more of a hybrid street and track tire. If you want strait line traction only mickey thompson makes an ET street DR in size 245/40/18.
Did not know that, Now I don't want either.
Will a 245 40 18 thompson et street radial fit on the stock rim without rubbing?
Also what do you guys think about the Kumho Ecsta V700, They are on Closeout right now for 165, only problem is its a 225 40 which is pretty narrow. But for the price they might be worth it.
http://www.tirerack.com/tires/tires....omCompare1=yes
Also they have the colored smoke Kumho Ecsta SPT for 188 in a 235 40 18 which is a little wider. I just don't know how good those tires are either.
Or should I just go with a 245 40 18 thompson? Will those fit?
Old Dec 9, 2009 | 06:37 PM
06_SIC_SS's Avatar
Originally Posted by Spins All Day
What size? 225? 235? 35 or 40 sidewall??? Rim Size 17 or 18?
my Mickeys are 245/40/18s
i also wanted a drag radial for the summer cuz ima be doin road racing, drag, etc.
http://www.summitracing.com/parts/MT...R/?image=large
heres a link to mine
Old Dec 9, 2009 | 09:06 PM
drewbroo's Avatar
its called driving like you have some self control when its wet. I don't race or drive aggressively in the wet. And I live in Tucson AZ, where there is not much of this wet you speak of. Great tire in the dry, and I also got them in 235/40/18's for 89.00 a tire
Those tires are terrible IMO. No wet traction at all.
Old Dec 10, 2009 | 07:34 AM
mron0903's Avatar
the V700 is a road racing r-compound, they are not drag radials and you won't benifit much from getting them. Your best buy is just looking for a specific drag radial. BFG makes decent street drag radials.
Old Dec 10, 2009 | 09:20 AM
Sweetsandman's Avatar
Damn those are expensive...Where do you plan on doing your road racing at cuz I'm lookin to do some of that next year and it would be fun as hell tryin' to keep up with you!
You wouldn't run those DRs on a road course would you?
Old Dec 10, 2009 | 09:37 AM
06blackg85ss's Avatar
mickey thompson et street II's 245x50x18's I actually got 2 for sale with less than 500 miles on em.
Old Dec 10, 2009 | 09:40 AM
mron0903's Avatar
your going to use these for road racing? Good luck with that! They're called drag radials for a reason, even if you attempted to road race you probably won't pass tech inspection with DRs on... It's so surprising how many ppl think getting autox/track tires will help them with drag racing and vice versa..
Old Dec 10, 2009 | 10:01 AM
  #36
Terminator2's Avatar
I agree. DRs are designed to have sidewall flex something you want very little of if you road course or autocross the car.
To each his own. They are inexpensive tires. They are way worse than the stock contis in the rain though and I get a ton of it here in Florida. I was not attacking you just stating a fact. Car and Driver did a test involving a ton of different tires including the stock Contis and the Hankooks. The Contis had a wet grip on the skid pad of 0.80 G. While the Hankooks had only 0.69 G of Grip. That is a huge difference for people who drive in the rain a lot. Their dry grip is good. Slightly better than the stock Contis at 0.94 G vs 0.93 G. The Hankooks also take 6 more feet to stop from 50 mph in the wet than the stock Contis.
Last edited by Terminator2; Dec 10, 2009 at 10:20 AM. Reason: Automerged Doublepost
Old Dec 10, 2009 | 01:07 PM
  #37
06_SIC_SS's Avatar
that kinda got mixed up and combined.. im gonna have other tires for the road course.. the MT's are for the strip.. and the highway
yeah they were expensive but i got em a lot cheaper than that.. yay discount lol anyways theres a couple road courses in cleveland.. theres one in kilcare i hear is fun.. they set up a road course hear at the fle market parking lot a couple times a summer because the lot is massive... theres one more im forgetting but were gonna have to hit em up for sure
Old Dec 10, 2009 | 02:01 PM
  #38
drewbroo's Avatar
I am not sure what the factors were in your testing but they have dropped my 60' by 2 tenths over the stock contis, and for cornering they are much nicer. Again wet traction is not a factor for me.
Old Dec 10, 2009 | 03:07 PM
  #39
Gettinausernamesucks's Avatar
You know I decided I need a new set of tires myself. I've been looking at the Nitto Invo. Since I have to suffer through snow (which sucks) I need somthing with a little block pattern. Granted the invo has little less than a conti which has literally none they look like they might be a compromise I can live with. Has anyone tried a set of these and used them through a winter snow season? The reviews on the Discount tire site look pretty positive.
Old Dec 10, 2009 | 03:25 PM
  #40
I did not test them, Car and drive tested them along with 10 other tires. Read what I wrote. Dry cornering is slightly better with the Hankooks. Braking in the dry is about the same. You are one of the few for which wet grip is normally a non issue. For the vast majority of us wet traction and braking is pretty important.
The Ecsta V700 are a R compound road course or autocross tire but they will have a ton more grip than the stock tires. They have only ~60 treadwear rating so they wont last long at all. MT ET streets are more suited to the Drag strip. Which tire you should choose depends on what your intended purpose is.
Last edited by Terminator2; Dec 10, 2009 at 03:25 PM. Reason: Automerged Doublepost
Old Dec 10, 2009 | 06:23 PM
  #41
MaxVQ35DE's Avatar
Uhhhhh, are you serious? Nittos in the snow!!!! HAHA
Old Dec 10, 2009 | 06:50 PM
  #42
slowbalt84's Avatar
lol wow. i wouldn't even use neogens in the snow
Old Dec 10, 2009 | 10:22 PM
  #43
I drove it all last winter on the stock conti's. What are ya wuss's Naw seriously theres only about ten days a year when its any kind of issue and I drive the HHR when the road isn't plowed or salted and its only 16 miles round trip to work. I ain't settling for all season crap tires or winter tires. I really don't have enough days I have to really deal with it to justify it.
Old Dec 10, 2009 | 10:47 PM
  #44
slowbalt84's Avatar
yeah me either. if it's too bad i can always use the wifes car
Old Dec 11, 2009 | 12:55 AM
  #45
your going to use these for road racing? Good luck with that! They're called drag radials for a reason, even if you attempted to road race you probably won't pass tech inspection with drs on... It's so surprising how many ppl think getting autox/track tires will help them with drag racing and vice versa..
I will probably just go with the Mickey's.
Old Dec 11, 2009 | 03:14 PM
  #46
06_SIC_SS's Avatar
^ they are nice
Old Dec 11, 2009 | 06:42 PM
  #47
MaxVQ35DE's Avatar
Wuss's, no were just not cheap fools , In chicagoland weve had 3 days in the last week where ive needed them.
All it takes is 1
-sleet
-turn
-icy intersection
-Moron in front of you
-storm you werent expected
i spent 250 on wheels, and 350 on tires. Its nice being able to stop going downhill in the snow, or be able to climb up a steep one. and its REALLY nice being able to stop with only 1 or 2 clicks from the abs in a few inches of crap. You spent how much on a cobalt, and your shopping a summer tire based on looks, as if looks mean good winter performance...
now that **** is funny
footballplaya3k
Wheels and Tires
Oct 8, 2015 05:24 PM
Redspire
Sep 16, 2015 07:08 AM
firishot34
Sep 5, 2015 01:09 PM
