aftermarket charge piping
Old Jul 23, 2009 | 07:55 PM
TCguy's Avatar
Im looking to put hahn charge pipes on my car, now, i know that my car has the "learn down" mode. So theoretically, do I have to get a tune in order to run these pipes? because wouldent they add better flow resulting in more horsepower and/or torque?
Old Jul 23, 2009 | 07:58 PM
BEASTmode632's Avatar
yeah they would but a tune helps a ton. save ur money for a tune first
Old Jul 23, 2009 | 08:24 PM
TCguy's Avatar
alright cool, thanks.
Old Jul 23, 2009 | 08:34 PM
purplehaze03's Avatar
i dont know why everyone says that you should not tune first! get your bolt ons and get tuned to your performance parts, getting tuned first is premature ejaculation!
Old Jul 23, 2009 | 08:43 PM
DjJoeski87's Avatar
Parts then tune
Old Jul 23, 2009 | 08:47 PM
Originally Posted by DjJoeski87
Parts then tune
thank you
Old Jul 24, 2009 | 01:59 AM
Boosted_Cobalt09's Avatar
parts then tune this way you dont have to keep retuning. you just wont see any gains until you tune.
Old Jul 24, 2009 | 02:01 AM
SSlobalt's Avatar
I prefer the "all together" theory. Plan your car, order your parts, put on the parts, get tuned the next day.
Old Jul 24, 2009 | 02:04 AM
L.P.'s Avatar
Parts and then tune are a great idea. Though I went with tune first since I really don't plan on going all crazy with it. May get a hot side charge pipe and a downpipe and then get the new tune that Trifecta came up with. I would recommend charge pipes for sure considering many say that the stock pipes can't handle heavy boost. I have stock piping and have been runing around 22 PSI for about 5k miles no with no problem but others may not be so lucky.
Old Jul 24, 2009 | 08:09 AM
DoMiStIc_RuSh_06's Avatar
i have the dejon upper and lower charge pipes, they are awesome and not that hard to install. I to believe that you should order the parts, install them, then get a tune. Just common sense that way you dont have to tune after every mod to get the most out of your car!
Old Jul 24, 2009 | 08:37 AM
IsItFast?'s Avatar
I agree with the above statement. Now that all the supporting/bolt on modes are in my car, its time to get the trifecta tune!
Old Jul 24, 2009 | 10:12 AM
wantedSS/TC's Avatar
I'm bolting on all my parts (listed below), putting my muffler back on and then getting tuned. Should be a fun month!!
Old Jul 24, 2009 | 10:13 AM
CudaJoe's Avatar
I think the charge piping is more for looks than power. I believe it frees up some restictive areas but overall performance isnt gonna increase by much at all. but thats my theory. none the less Im still gonna get them!
Old Jul 24, 2009 | 10:18 AM
northvibe's Avatar
charge piping alone is not going to require a tune, thats ridiculous. If you just want CP get it and dont worry. Until you are a stage kit or tuned the engine will learn down to stock anyway. So get the parts you want first.
Old Jul 24, 2009 | 10:21 AM
charge pipe (hot side is the route to go). The cold side isn't that restrictive (plus it's a BITCH installing). There are performance gains with Clear Image's Performance version of the CP. at least 10whp.
You won't need to retune for a CP. I would retune however with a DP and intake.
Old Jul 24, 2009 | 10:41 AM
Mazdaboi318's Avatar
yes true....
Old Jul 30, 2009 | 05:50 PM
TCguy's Avatar
ok with all this being said and greatly appreciated...one more question....Lets say i bolt on the injen hot side pipes on a completley stock engine (no tune)...it wont thrown any check engine lights or limp mode will it?....noob question i know.
Old Jul 30, 2009 | 06:03 PM
ClearImageAuto Dan's Avatar
Hot side boost tubing should be a required mod. I sa this because the stock plastic part has been known to crack/split apart. On the dyno, we literally ran away from the car as the stock part had swelled and moved a couple inches while under boost.
Stock style boost tubing, or what we refer to as our "appearance" boost tubing, showed maybe 1 HP over stock. But our "Performance" boost tubing was good for 6 HP to the wheels.
If you have to choose, I suggest the hot side first then the tune.
Old Jul 30, 2009 | 10:44 PM
yahhh, my bad 6, not 10
Old Jul 31, 2009 | 12:01 AM
Nakaiya21's Avatar
You can run your car just fine with new charge piping without a tune... I did that with mine until my other mods came in. You can also do the same with a dp. However, when it comes to the intake, I would tune immediately after putting that on as I found a lot of tweaking was required when it came to mine... Our cars are very picky when it comes to intakes...
Old Jul 31, 2009 | 08:13 AM
Iam Broke's Avatar
When I put the AEM CAI on, I had to tweak the MAF table about 9% due to the larger diameter of the intake. LTFT's went to +9 to +14 depending on conditions. MAF went up from 30 to 32 since it can breathe better now. (21.5 PSI boost)
Jan 12, 2016 12:01 AM
717ssbalt
Oct 2, 2015 04:01 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
