alot of vibes with ottp rotated mounts
i am getting alot of vibes at idle after installing the stage 2 mounts. anyone else get this? also getting alot of vibes/shaking when i am releasing the clutch in first.
is it possible i installed something wrong?
after looking back at the install the only thing thing i might have done wrong was i tightened up the front mount before i got the rear one.
should i take them out and try it again? should it really matter which was installed first? the 3 motor mount bolts were the first thing i loosened and the last thing i tightened
i tried it with the heat and ac on.
those that say no increased vibes you have to be nuts. as soon as i got it the car it felt like a rattle box
if this is how they are i might try stage 1s
With AC on, you feel it at idle (as in stock as well)..no biggie.
I don't have OTT rotated mounts. I have full urathane mounts though. By far much harsher than what you have. When I first installed them they where preaty bad. You'll notice they will get smoother after they settle.
There were almost no vibes with Stage 1, however there was still wheel hop at times. The vibes came on with Stage 2 (especially, as someone noted, with the a/c) but it eliminated wheel hop altogether, so I prefer the Stage 2.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
importkiller
Sep 30, 2015 07:18 PM
