Another LNF missing an injector seal.
Old Jan 3, 2012 | 12:40 PM
  #76
FasterIsBetter's Avatar
Originally Posted by FrossB
Sounds like spark blowout man. You're already at full boost before this happens so I would assume it would do this then but instead it does it when you get in the upper rpms at full boost. Whats your plugs and gap?
Old Jan 3, 2012 | 02:09 PM
  #77
InfraRedline's Avatar
Check for boost leaks before you do anything. That sounds like what Cody's car did before we fixed 3 huge leaks. Maybe make a video of a 3rd gear pull if you can so we can get a better idea of what's going on.
Old Jan 3, 2012 | 02:50 PM
  #78
FrossB's Avatar
Thread Killer
I have NGK plugs at .030. And I wouldn't think I would have a boost leak cuz I'm hitting the desired boost that my tune is set to.
Old Jan 3, 2012 | 03:31 PM
  #79
Chevycobaltss3's Avatar
Lol we will figure it out... Its not a boost leak. Id be able to see it. It's not spark blowout, my aummption so far is its either the seal or topend
Old Jan 3, 2012 | 03:47 PM
  #80
donkeyballs's Avatar
I think i haz this problem ill post a video of the sound shortly
thats kinda what my car sounded like before i changed plugs and gapped to .29 lol I also had a minor boost leak so that added to the problem.
Old Jan 3, 2012 | 03:53 PM
  #81
FrossB's Avatar
Thread Killer
Better figure it out!!!!
Old Jan 3, 2012 | 05:36 PM
  #82
Just because you have a boost leak doesnt necessarily mean you wont hit your desired boost level. Your car seems to spool slower than cody's but that could be a number of things. All im saying is for the $5 it takes to make a boost leak tester its worth the peace of mind. Might as well start out with the easy things before jumping to the more difficult and expensive things.
Old Jan 4, 2012 | 01:59 AM
  #83
FrossB's Avatar
Thread Killer
yea i was informed of that after i posted it lol im going to be doing a boost leak test this weekend
Old Jan 4, 2012 | 02:02 AM
  #84
Here's a little tip when looking for boost leaks. Find a 3/8" or so hose thats a few feet long and put one end in your ear and take the other end and poke it around the engine bay to suspected leaking areas. You'll know when you find a leak lol
Old Feb 3, 2012 | 08:04 PM
  #85
cmiller8006's Avatar
Those that put the new injector seals in, is this how it goes? My friend wasnt at the shop today so I could get the SI info. Thanks
Old Feb 4, 2012 | 09:03 AM
  #86
Iam Broke's Avatar
Yep, carefully slide the seal over the injector tip and then use the cupped end of the other tool to shape it into the relief on the injector so it'll insert into the head properly.
Old Feb 4, 2012 | 09:34 AM
  #87
Thank you.
Old Feb 4, 2012 | 03:11 PM
  #88
Iam Broke's Avatar
Careful now...don't want to split it. lol.
Old Feb 4, 2012 | 03:41 PM
  #89
I am done with it lol. All went well. Well except for me forgetting the foam over the injector rail, and not finding that till the IM was torqued down.
Old Feb 5, 2012 | 08:01 AM
  #90
Iam Broke's Avatar
Oh well, so it'll tick a bit louder. No biggie.
Old Feb 5, 2012 | 11:26 AM
  #91
I put it back on. By the way all of my seals looked good. And I have run race gas as well as alot of boost. So maybe they are not friendly to e85.
Old Feb 5, 2012 | 01:06 PM
  #92
Iam Broke's Avatar
That might be the case with the original white ones.
Old Feb 5, 2012 | 01:22 PM
  #93
Yea thats what I meant.
Old Feb 5, 2012 | 08:22 PM
  #94
2009sstc's Avatar
seal
finally got around to pulling out the injectors in my car, and one of the injectors was missing a seal. Had the exact symptoms that IamBroke listed.
Im running on e85 mix and did seafoam maybe 5k ago or so.
Old Feb 5, 2012 | 08:41 PM
  #95
Just replaced team Ss injector seal. One was missing .. 1 cylinder. All others were getting burned up... I replaced them as well ..
Old Feb 5, 2012 | 08:58 PM
  #96
Lol, I wonder how you did that?
Old Feb 5, 2012 | 09:07 PM
  #97
ccss3 was it an E blend tune on the car?
Old Feb 5, 2012 | 09:22 PM
  #98
Yea, bnr 2871 e47
I didn't use ure tool lol ..
[[/B]
Last edited by Chevycobaltss3; Feb 5, 2012 at 09:22 PM. Reason: Automerged Doublepost
Old Feb 5, 2012 | 09:44 PM
  #99
Ah, lol. Did you even use a tool?
Old Feb 5, 2012 | 11:58 PM
  #100
Lol no, I have my ways....
