Another one bites the dust
Old Jan 20, 2010 | 10:22 AM
  #51
iboost's Avatar
lol...thats ****** sick
Old Jan 20, 2010 | 10:43 AM
  #52
09CobaltSS1's Avatar
Originally Posted by Edubs
There is more to a tune than peak boost. I doubt you have the same settings as GM.
Regardless, I never claimed that you modified the piping and I haven't seen anyone else have this type of failure. I'm not trying to pick on you or anything, but it's likely that you'll have this problem again...
...why make yourself and the dealer go through the hassle of replacing it if the problem can be avoided. You said it yourself, GM is "cheaping out" on the piping and your right that it definitely does not seem up to the task of handling your tune. Just upgrade it and never worry again. Again, just trying to help you resolve the issue.
Had my hot side break right in half on the stock tune, and guys on here are apparently getting away with upwards of 30psi without blowing the stock pipes. My break wasn't quite as dramatic as the OPs but it still busted pretty good. Point being, these charge pipes don't seem very consistant so you really can't place the blame on him for running more boost although it obviously didn't help by any means. Dealer replaced mine with no questions asked...
Old Jan 20, 2010 | 10:47 AM
  #53
1BADSS/SC's Avatar
Boy, GM sure does use high quality plastic on their cars...
Old Jan 20, 2010 | 04:07 PM
  #54
FRQ FLYR's Avatar
No problems yet; had mine replaced per service bulletin. Maybe the replacements are stronger
I guess the cheap underhood/interior plastics help make the car lighter and more affordable but...I'm GMS1 now and do not wish to duplicate this; piping WILL be next mod.
Old Jan 20, 2010 | 05:25 PM
  #55
09BlueBaltSS's Avatar
Was at the dealer earlier. Theyre ordering me the new pipe along with a new battery vent tube cause thats all cracked to hell. Should be good by middle of next week. Then ima start saving my pennies for some boost worthy piping
Old Jan 20, 2010 | 09:05 PM
  #56
07cobaltguy's Avatar
The material gm used for that is, cheap and very easy to process, but also has good hot and cold weather properties. I will say useing polyethelyen for charge piping, not smart, but deff a good way to save a few bucks. The "pancaked part" as you guys called it, is actually called the Parting Line, it is also one of the weaker points as you are all finding out. Of course there are ways processing around this issue and GM's injection molder deff dropped the ball on that one. They shouldve made it out of a glass filled nylon just like the end tanks on the intercoolers, much more durable. I'm an injection mold process tech by the way.
Old Jan 21, 2010 | 09:04 PM
  #57
jgfnova's Avatar
That sucks!!! Did it dent the hood at all??
Old Jan 22, 2010 | 11:26 AM
  #58
No, thank god. Thats the first thing I went outside to look at the next morning lol
kzak104
Oct 11, 2015 05:19 PM
GSoccer24
How to Guide
534
Jul 15, 2013 09:16 PM
clint06ss2.4L
Apr 17, 2006 07:48 PM
abstract
Nov 23, 2005 06:13 PM
