Back fires at WOT
Back fires at WOT
Ok so I have had a boost leak for awhile and I have fixed it but when I go over 15psi or WOT the car back fires, I do not have any codes what does this mean?
If you're not hitting the fuel cut and you don't have an overboost code, you must have an incomplete burn. Without a misfire code, you won't know which cylinder to check, but you could have a bad coil, but it's probably as simple as a fouled or worn plug. Remove and replace spark plugs, checking all gaps. Check old spark plugs for color.
If that doesn't solve it, you're probably looking into the cam position and crank position sensors.
You could have a bad post MAF leak or your injector seals could be going (I see you're on E85). Does it sound like popcorn?
12.1 is believable ie drag radials or slicks. His trap speed for the power seems a little high.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
