Back fires at WOT
Old Jul 28, 2012 | 11:30 AM
beast10007's Avatar
Back fires at WOT
Ok so I have had a boost leak for awhile and I have fixed it but when I go over 15psi or WOT the car back fires, I do not have any codes what does this mean?
Old Jul 28, 2012 | 01:32 PM
Zander916's Avatar
Misfire? Unburned fuel igniting in the exhaust?
Just a guess.
Unless you're hitting the limiter.
Old Jul 28, 2012 | 01:40 PM
hawkssoccer11's Avatar
make sure your spark plugs are ok, gapped properly and torqued correctly too
Old Jul 28, 2012 | 01:44 PM
noorj's Avatar
you really ran a 12.1 on the stock turbo? got a vid or the slip? that's very impressive.
Old Jul 28, 2012 | 01:46 PM
Dart_SI's Avatar
this. props if so.
and X2 on checking your plugs. sounds like you need to replace them and make sure they are gapped properly.
Old Jul 28, 2012 | 02:14 PM
SSlobalt's Avatar
If you're not hitting the fuel cut and you don't have an overboost code, you must have an incomplete burn. Without a misfire code, you won't know which cylinder to check, but you could have a bad coil, but it's probably as simple as a fouled or worn plug. Remove and replace spark plugs, checking all gaps. Check old spark plugs for color.
If that doesn't solve it, you're probably looking into the cam position and crank position sensors.
Old Jul 28, 2012 | 02:18 PM
Frogstofall's Avatar
You could have a bad post MAF leak or your injector seals could be going (I see you're on E85). Does it sound like popcorn?
12.1 is believable ie drag radials or slicks. His trap speed for the power seems a little high.
Old Jul 28, 2012 | 02:19 PM
SSlobalt's Avatar
Oh, good call Frog. I missed the E85 thing.
Old Jul 28, 2012 | 02:26 PM
noorj's Avatar
Isn't the record for a stock turbo an 11.9? I would say 12.1 requires some damn good driving
Old Jul 28, 2012 | 02:27 PM
Like I said, it's believable.
Old Jul 28, 2012 | 02:58 PM
AARON-SS-TC's Avatar
especially with a stock clutch, but hey props to you..thats damn fast
Old Jul 28, 2012 | 03:00 PM
noorj's Avatar
haha gotcha frog. so lets see the slip!
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
Oct 20, 2015 09:56 PM
dennis69
Oct 20, 2015 04:49 PM
Trav3480
Oct 1, 2015 08:17 PM
