Back in the Saddle
Old Jul 30, 2013 | 10:46 AM
Kbbalt's Avatar
Thumbs up Back in the Saddle
So i have been MIA for a while, I got Laid off a couple of months back. But i recovered quickly and have been working my new job for about a month now. Funds are flowing back in.
So, You guys are in for a story about my night last night. Once i get the videos loaded.
Anyway. Im starting back up on my ZFR Build very soon. and have lots of questions.
So it looks the the stock Clutch cant handle anything the ZFR puts out.. and from what i reading neither car the Trans...anything i should be wary of?
Im ordering the pig tails for the 3 bar, and also the GMPP fro CED.
I Have EVERY bolt on for this car right now. is there any recommendations for addtional stuff with the ZFR? I heard Boost ramp was a great idea with it. any Advice would be great.
And is anyone running a e85/93 Mix in there LNF's?
thanks guys.
Old Jul 30, 2013 | 12:33 PM
Fastgti69's Avatar
Boost ramp was a must for me because of traction and drivablilty in the canyons. And to play it safe with my tranny and for the fuel to catch up. The turbo spools too fast so that fueling can be an issue at lower rpm because it's chain driven. I was running e85/91 which is pretty much the same as your 93 if we're mixing. It's an e47 blend and was amazing. Highly recomend it but you will max out your fueling systems before the turbo is maxed out. Just make sure to be at high rpm when going WOT. Don't do high gear low rpm wot, that's what kills the tranny. Low end torque is the killer and the ZFR has a lot.
Old Jul 30, 2013 | 04:28 PM
Kbbalt's Avatar
So pretty Like i Drive now, Downshift before WOT? I usually dont go Wot in high gears with Low rpms.
Do you think the Clutch is a absolute must?
I will probably go straight 93 for now. until i get just to everything. Thanks again.
Old Jul 30, 2013 | 06:25 PM
RYRO14's Avatar
If you DD your car, I would get the GMPP clutch. Ive heard nothing but good things about it.
Old Jul 30, 2013 | 06:27 PM
user 72239's Avatar
This. get the GMPP clutch. There seems to be a correlation between higher load bearing clutches and transmission failures.
Old Jul 30, 2013 | 06:38 PM
Wert842's Avatar
Get a better trans. Haha. Mine just broke.
Sent from my Samsung Galaxy S4 using CobaltSS
Old Jul 30, 2013 | 08:18 PM
Fastgti69's Avatar
Yes, try to be at the highest rpm in the lowest gear etc. Yea clutch is a must with ZFR, so much low end torque it will need it. It will take a while to adjust to the ZFR after 93 you'll get bored then go e47.
Old Jul 31, 2013 | 03:28 PM
Kbbalt's Avatar
Fast Gti, What happened with your ZFR?
Old Jul 31, 2013 | 05:13 PM
joshsal123's Avatar
So u mean a stage 4 clutch isn't the way to go?
Old Jul 31, 2013 | 07:25 PM
tomj77's Avatar
I'm sure ky clutch would be just fine
Old Jul 31, 2013 | 08:01 PM
joshsal123's Avatar
I'm in the same boat as op boltons and zfr and I'm not sure wat clutch to get now
Old Aug 1, 2013 | 12:35 AM
Fastgti69's Avatar
My prototype ZFR blew back in March on my way to a 1/2 mile drag strip lol.
Old Aug 1, 2013 | 08:17 AM
r3v07ut10n's Avatar
I have a KY-stg 3 clutch and it is holding fine. I dont have any boost ramping on my tune, but i do have a dual tune which helps me alot. Look at my Dyno sheet to see what i made. Lots of low end torque.
https://www.cobaltss.net/forums/dyno...2/index18.html
mind you.. driving normal on regular tune blows 285/285 .. not that same as 410/377
Old Aug 1, 2013 | 02:12 PM
Kbbalt's Avatar
Thanks Rev, How long you been Tuned? I see that on Meth Also.
Old Aug 1, 2013 | 03:47 PM
r3v07ut10n's Avatar
Since saturday lol
turbochargedss2012
Sep 20, 2023 12:17 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
Oct 20, 2015 09:56 PM
dennis69
Oct 20, 2015 04:49 PM
Trav3480
Oct 1, 2015 08:17 PM
