Bad Day on the Dyno :( help?
well i went to the dyno today for a couple pulls with my intake, dp, and trifecta tune just to see what i was making as pulls were only 45$ for a set of 3. Well i get strapped down, start car, ebrake is off, TC is off and Trifecta is engaged. Car taps out at 4200 and ABS light comes on, service TC, service ESC then it said ESC off, tried it again, same issue. Roll off the dyno ABS goes off so i turn around and get back on the dyno lol. No abs light, TC off once again, 4200 RPM car taps out and ABS light comes back on. ( made 310/344)
steps:
start car
ebrake off
TC off
Trifecta engaged
Punch it at 2300 rpm
Taps out at 4200
ABS light and service lights all come on.. WTF
steps:
start car
ebrake off
TC off
Trifecta engaged
Taps out at 4200
My car kinda did the same thing except it didn't max out the rpms. It was freaking out though, and the damn chime kept going off. Try disconnecting the rear wheel speed sensors next time and see if that helps at all.
i couldn't think off the top of my head what would be wrong, unless a speed sensor is going out, but that wouldn't explain why it turned off when he started driving again...
someone help my little bro out??
Pretty much your car is shutting down cause it sees your front tires spinning but not the rear. so it shuts down cause it thinks it's protecting itself from damage. try unplugging the front abs sensors and strapping them in place so they wont get caught by anything moving and try again.
disengaged ESC second time around, did not help at all
Same thing happened to me 2 weeks ago. I told the guy to hold the traction button for ESC to turn off not just to turn traction off. "Ive been doing this for 15 years." I don't give a ****, you don't know my car..
The way I dyno'd with TF was press the tc button twice then hold it down til it said "esc off" Make sure Vince has the tune active in tc off mode as well. Oh and btw the abs light came on when I dyno'd but the rpms werent limited. The abs light will go away after you drive a couple mins
and mine also freaked out the other day when i did mine but my RPM's were not limited
Iceberg
Sep 29, 2015 12:33 PM
