bad results
Old May 13, 2014 | 04:11 PM
jaygo7007's Avatar
bad results
so today while idling noticed white smoke coming thru the exhaust. just a tad so i pulled over and checked the oil dipstick and there was no oil. so i bought a 5 gallon jug and it in and proceeded to drive. so while im driving tons of smoke pours out the exhaust. so now i freak out, drive to a performance shop (houston z) to do a compression test.
the result
cylinder 1 150 psi
cylinder 2 165 psi
cylinder 3 60 psi
cylinder 4 90 psi
so now im guessing the cobalt is done for.
the estimate for the repair is 3840.47. is this about right?
he also removed the coupler from the turbo and there was a puddle of oil sitting there
Old May 13, 2014 | 04:15 PM
alerosaint's Avatar
the result
cylinder 1 150 psi
cylinder 2 165 psi
cylinder 3 60 psi
cylinder 4 90 psi
You can get an LDK for that amount
Old May 13, 2014 | 04:17 PM
KMO43's Avatar
Buy a gen 3 engine from ZZP $1500
Old May 13, 2014 | 04:21 PM
jaygo7007's Avatar
i see zzp it for 1700. if i was to go that route all that has to be done is to disassemble the block, swap bottom, and reassemble?
Old May 13, 2014 | 04:23 PM
taintedred07's Avatar
$1500 is just for the block
Get a complete drop in LDK for around $3k imo
GM ACDelco - Complete LDK Engine #
KMO43's Avatar
There may be a coolent hose or line issue that I heard of but I really don't know but yea bolt on good to 500hp they're saying just run oil in it and it'll last you
Old May 13, 2014 | 04:31 PM
jaygo7007's Avatar
now i need to find a way to get 3000 smh
Old May 13, 2014 | 04:42 PM
KMO43's Avatar
Nope $1500 fully assembled short block
ZZPerformance - Gen 3 LNF/LDK Short Block #ZZ-LDKSB
A long block is the complete engine oil pan to valve cover
ssyellow's Avatar
Set aside some extra cash for a new tune also.
Old May 13, 2014 | 04:59 PM
08VRSS's Avatar
I want to go this route when my LNF goes bye bye. Can you just get the short block and bolt on all the LNF goodies and head, ecu, etc. and good to go?
Old May 13, 2014 | 05:08 PM
KMO43's Avatar
Yes and it has a bit more compression so it'll make more hp
Old May 15, 2014 | 07:24 AM
mongorat427's Avatar
I bought the ZZP short Block and took it apart . Got Wiesco pistons and Molnar LNF billet rods. Taking it up for a hone job. Total cost $2400 for a forged brand new bottom end
Old May 15, 2014 | 09:54 AM
tomj77's Avatar
Then u need to add in the bolts and gaskets u need to put it back together. People add everything u need to buy so he can have an accurate price
Old May 15, 2014 | 01:30 PM
KMO43's Avatar
Ya this is what I would like to do
Old May 15, 2014 | 02:07 PM
r3v07ut10n's Avatar
this is on my list to do already. Im just waiting for the day....
Oct 13, 2015 09:32 PM
ernnyyes
Oct 2, 2015 05:16 PM
Iceberg
Sep 29, 2015 12:33 PM
Trav3480
Sep 28, 2015 02:46 PM
Iceberg
Sep 28, 2015 01:31 PM
