ballAr stock injectors???
Old Dec 24, 2008 | 04:26 PM
Chandler's Avatar
Question ballAr stock injectors???
All of the modification threads I have read , say nothing about swapping the stock injectors. Are people getting these good number on the stockers?
Can someone post some specs of them for me? And where the limit is approximately on them.
What is the Duty Cycle from the factory at? High/low imp? etc.
Thanks
Old Dec 24, 2008 | 04:45 PM
krispy's Avatar
Maybe someone that has tuned the engine can chime in, these injectors are high pressure and can't easily be swapped out to my knowledge. When I first was looking the static flow numbers of the injector was something stupid like 110-120+ lb/hr, if the static and dynamic don't change ridiculously we shouldn't be limited by them anytime soon.
Old Dec 24, 2008 | 04:47 PM
Area47's Avatar
Rent me! per hour
the idc of the direction injection cars is higher than what people think
Old Dec 24, 2008 | 04:48 PM
steddy2112's Avatar
My IDCs I think were like...30 last time I logged at 22 psi
I thought the fuel rail is what couldn't handle it not the injectors per se
Last edited by steddy2112; Dec 24, 2008 at 04:48 PM. Reason: Automerged Doublepost
Old Dec 24, 2008 | 04:52 PM
slowswap's Avatar
My friend had a 35r speed 6. The only thing he had to get was a higher flowing fuel pump to keep up with the demands of the injectors.
Old Dec 24, 2008 | 04:54 PM
krispy's Avatar
the fuel pump should be pretty limiting on the Cobalts too
steddy2112's Avatar
That fuel pump must have been expensive...I wasn't aware that there were aftermarket DI cam driven fuel pumps.
Then again I have never really looked.
Old Dec 24, 2008 | 05:06 PM
Terminator2's Avatar
He is right even though it will read 30% it is actually almost double that because the injecter pulse is different than normal port injection. That is what I have heard anyway.
Old Dec 24, 2008 | 05:08 PM
Area47's Avatar
Rent me! per hour
give em a cookie!
Old Dec 24, 2008 | 05:09 PM
steddy2112's Avatar
That's right
Hey now it's been awhile but its coming back
I know the original plan for the stage kit that is being released now came with a better fuel rail as well.
Old Dec 24, 2008 | 05:20 PM
Chandler's Avatar
awesome, so for the regular port part of my brain , it would be safe to assume that the "idc" is around 57-60%?
Old Dec 24, 2008 | 05:24 PM
steddy2112's Avatar
Oh don't quote me
I think it is like 30 something.
I am teh lazy today
Old Dec 24, 2008 | 05:25 PM
peachpuff's Avatar
The injectors are huge, probably around 120-130lbs ones, but they can only spray during the intake stroke. Once you start injecting fuel into the compression stroke you lose the effectiveness of direct injection and lose power. They seem to be good for 400whp or so.
IDC is between 25-30% depending on mods.
Old Dec 24, 2008 | 05:27 PM
steddy2112's Avatar
IDC is between 25-30%.
120-130 lb/hr
Not physically 120-130 lbs
Just to clarify things
Old Dec 24, 2008 | 05:30 PM
krispy's Avatar
Originally Posted by steddy2112
120-130 lb/hr
lol
injectors that heavy do exist though on marine diesels
Old Dec 24, 2008 | 05:31 PM
steddy2112's Avatar
The car would be so heavy
Old Dec 24, 2008 | 05:45 PM
ItalianJoe1's Avatar
I knew I wasn't the only one who understood that.
Old Dec 24, 2008 | 05:46 PM
peachpuff's Avatar
120-130 lb/hr
You know what i meant
Increasing the fuel pressure might give us a bit more headroom, but we don't have control of that yet.
Old Dec 24, 2008 | 05:47 PM
Oh don't quote me
I am teh lazy today
The calculated IDC is 30%, but you cannot go to 100% on a DI motor, so the threshold is different. People that see 30% and assume they can run 3x the fuel and be safe, that is not the case here.
Old Dec 24, 2008 | 06:55 PM
cobaltssoverbooster's Avatar
irect injection injector what?@?@?
Some facts on the 14 cylinder version:
Total engine weight: 2300 tons (The crankshaft alone weighs 300 tons.)
Length: 89 feet
Height: 44 feet
Maximum power: 108,920 hp at 102 rpm
Maximum torque: 5,608,312 lb/ft at 102rpm
fuel injector height is 2 1/2 stories tall
Old Dec 24, 2008 | 09:45 PM
HunterKiller89's Avatar
Length: 89 feet
Height: 44 feet
swap the bolded parts with the underlined parts and you have a honda!
Old Dec 24, 2008 | 10:25 PM
slowswap's Avatar
Only if you add 2 zeros to those RPM's. LOL
Old Dec 25, 2008 | 01:36 AM
its all true
Supercharged06SS
Dec 11, 2022 04:47 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
Stuff
Oct 1, 2015 05:47 PM
