Best Clutch for NLS
Old Jan 24, 2012 | 07:15 PM
iLikeBoost's Avatar
Originally Posted by Chevycobaltss3
You guys are arguing about what clutch is best for nls.. when you should be asking which driver is best honestly. Because its all on time.. the stock clutch isn't meant to be nlsed on a higher Tq rated car. It'll do it but not for long. Anything rated under your power won't hold for long so your just asking to get your clutch replaced again..... Lightweight flywheels are pointless on a dd car ecspecially since the rev issue.. so a stock one unsurfaced is best but if you can not afford it then get it resurfaced. Do you have to? No, but there are the possibilitys of heat and cracking. So which clutch is best to hold a nls and the power output. A 6 puck that's worth it and the money.. I have worked with a southbend 8 puck.. and it did not last long to a lnf with just a tune and a few mods.. and I also did a lsj full bolt ons and a southbend 8puck kevlar and it wasn't holding his power. Point of me telling you this is order a clutch rated to your power.
Ky clutch has the best materials and have tested out all pressure plates and friction discs to make sure clamping force is where it is supposed to be on every single clutch they sale. And better yet, you don't need a adjustable clutch rod for engagement depending on clutch you order.
This
Old Jan 24, 2012 | 07:19 PM
09BlueBaltSS's Avatar
explain further
TurboTechRacing's Avatar
I couldn't agree more!
Old Jan 25, 2012 | 03:17 AM
Berto09ss's Avatar
I dont smash on car by any means on a daily basis but i would like a good set up for the drag strip, plus an aftermarket clutch is better than stock, and i dont NLS like most people
Old Mar 5, 2012 | 04:46 PM
gray ss/tc's Avatar
My clutch just started slipping. I'm really considering ky stage 3
Old Mar 7, 2012 | 07:03 PM
Order one up asap, you dont want to be without a clutch...
Old Mar 7, 2012 | 11:25 PM
TurbodChico's Avatar
Man, totally agree with chevycobaltss3. what bothers me is this hobby, it appears to me people are scared to wrench. you beat on it, shes gonna wear out clutches are made of friction material. NLS kills clutchs kills trans, axles, hubs, the list goes on. if you dont like the catch with NLS then simply do not use it. nobody told you to race that S4..lol. now say you reinforce every aspect of your driveline and still shatter that "bulletproof" axle. i dont know about you guys i would be proud of saying i could do that.. take pride in making massive amounts of power from small underated powerplant and destroying it pieces. BECAUSE I CAN FIX IT..lol and to those that cannot, save your pennies change your driving habits or hobbies..
anybody ever made a SUCCESSFUL NLS with MASSIVE TORQUESTEER @ 80...i think i need to do more push ups..lol
Old Mar 7, 2012 | 11:27 PM
Stamina's Avatar
One does not simply race an S4. One must beat an S4. lol
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
