Best Intake?
Old May 25, 2011 | 01:11 PM
  #51
M-Dub's Avatar
Originally Posted by BooSSted
You might want to do some reading on long term results. So far what I know is that the Hahn charge pipes don't fit for **** and there have been a few people that have had their hoods dented from the inside. There is also 2 threads on here about end tanks blowing apart on their intercoolers. Their quality is easily beaten by every other vendor on this site, so we don't even need to get into how over priced their products are.
I have the K&N SRI and the fitment, quality, looks and performance are top notch. The only Intake I would put ahead of it is BYT's as far an performance.
As far as IAT temps, mine never exceed the outside air temp, so don't give me any crap about the filter sucking heat from under the hood....
Post up a log of your IAT1s in 90+* heat... and I will show you mine... And if you are to blind to see the difference in heat... then well you just solely can't be helped.
Reading... on results.... I have been part of SAID results since these cars came out... so dont' give me any CRAP about reading....
Old May 25, 2011 | 01:56 PM
  #52
nobody2u's Avatar
Originally Posted by M-Dub
It's similar, to a Typhoon intake... just isn't as pretty.
If thats the case, which is better?
Old May 25, 2011 | 01:59 PM
  #53
M-Dub's Avatar
I would do the SRI over the Tyhpoon I didn't even know K&N had 2 different intakes for the LNF?
Old May 25, 2011 | 03:28 PM
  #54
nobody2u's Avatar
I guess so. I'm not quite able to find anything comparing the two though.
Old May 25, 2011 | 10:53 PM
  #55
09TcSedan's Avatar
same here. i have only found the K&N typhoon SRI intake. 260$
Old May 25, 2011 | 11:26 PM
  #56
nobody2u's Avatar
Maybe there is only one and I'm just being a noob. It's quite likely.
  #57
matt638's Avatar
hahn
Old May 26, 2011 | 12:19 AM
  #58
SSlobalt's Avatar
Hahns parts are ****.... just grosly overpriced. But the quality is hard to beat!
No...........it's not. Holes in IC endtanks, rusty/flaking intake internals, and chargepipes with no block-mounts? Bah. They can sit and spin.
Old May 26, 2011 | 01:37 AM
  #59
TurboJoe's Avatar
Alot of talk until we see visual proof, ie back to back dyno or track times. From all the results i have seen there is still no reason to purchase a 260 dollar or more (hahn) intake over the cheap do it your self Airbox mod +drop in and zzp inake tube...
Old May 26, 2011 | 02:33 AM
  #60
BooSSted's Avatar
Your idea of a "Fantastic" exhaust is one that had to be modified to fit your car so that it didn't bang.... Your credibility on rating parts in now 0
I'll get back to you on the logs when it gets to be more than 75* here
Old May 26, 2011 | 02:45 AM
  #61
BooSSted's Avatar
Are you for real? You just made a recommendation on a part, and admitted that you didn't even know it exists, all in the same sentence.... So what are you basing your opinion on?
There is only one K&N intake system for the LNF guys. It's called a couple different things depending where you see it. But it's all the same thing.
Old May 26, 2011 | 04:30 AM
  #62
M-Dub's Avatar
Had to be modified for a heavily lowered car... wow dude. I honestly could careless really what your feelings are on my credibility...
But for those that actually come to me for advice (which there are QUITE a few, as I have tuned over 75 cobalts around the country maybe even more)... I do know a thing or 2 about these cars and the platforms in general.
Cold airs will always yield cooler IATs... they almost always show an increase in top end responce. Not that the SRI won't do that... but I know GMtunersource did a dyno study on 3 intakes... on a GMS1 car and the HAHN showed a 23whp difference while the others were between 10-15whp.
Thats not me... thats an outside source. Tuning wise the HAHN seems to be the most stable. I know a buddy of mine has the K&N and his tuned out pretty easily to. SO on that note they are pretty comprable.
Any other questions feel free to ask. But MY HAHN parts, have been fantastic. And I will repeat, anything other than pedders your exhaust will hit the twisting beam, it's easily modified by changing the angle of the over axle portion.... My HAHN intake has performed flawlessly! I can't speak of the rest as I do not and have not ever owned them... their charge pipes hit on some cars, and their intercoolers pop welds, but so does synapse's i/c's as I went through 2 of them... I don't say theya re a bad company because their turbo manifold is ******* beautiful! And works FLAWLESSLY!
kthxbai
Old May 26, 2011 | 09:39 AM
  #63
Matt M's Avatar
kthxbai
A couple corrections-
The ZZP silicone coupler is more "stable" than the Hahn intake.
ZZP catbacks do not hit on the rear beam.
Old May 26, 2011 | 10:33 AM
  #64
09sscalicobalt's Avatar
nice and again i know why im going with zzp performance parts for my lnf althought my dp and exhaust are megan racing but they were free 99 lol
Old May 26, 2011 | 01:13 PM
  #65
M-Dub's Avatar
I have tuned a ZZP coupler and of course it is LOL it's using the stock airbox... I havent' had nor used a ZZP catback so I cannot report on them.
But I like your products never had a single issue so far.
Old May 26, 2011 | 01:31 PM
  #66
rallycobalt06's Avatar
how about the spring seat?
Old May 26, 2011 | 02:40 PM
  #67
Matt M's Avatar
I have not had any clearance issues at all on my car or any that we have installed here.
Old May 26, 2011 | 02:41 PM
  #68
that's good hear
Old May 26, 2011 | 05:07 PM
  #69
M-Dub's Avatar
Thats awesome matt.... I have the hahn well because I had it on my lsj so it was convinent...
DarrenGC
Dec 24, 2021 01:55 PM
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
OrangeCoba
Sep 25, 2015 06:06 PM
