blown tranny?
so its a 2008 lnf, im on the 5th clutch i put it in probably 5000 miles ago, anyways it shifts pretty crunchy into every gear n wen i let the clutch out i hear a winding noise, does it sound like a tranny issue or just have another broken clutch!? pray for me that its my clutch. ill have a answer in 2 hours wen hopefully pieces of the clutch hit me in the face lmao
Edit. Reading the post again. It's hard to tell since with the clutch not engaged you have a sound. Could be either
yep 5 of em its been outstanding n i had 3 oem clutches n 2 stage 4 clutchmasters but i been using the stock flywheel this whole time n just bought a aluminum zzp flywheel yesterday since there was a discount. the hub like breaks away from the center n it breaks the arms that hold the springs in place im assuming my flywheel may have been bent or warped or my input shaft on the tranny is bent if this one breaks im gonna assume my input shaft is bent
LSX RWD S/C conversion
I can second that, I've snapped the factory one, 2 fx100 clutchmasters. I've never dumped mine or used the factory launch control or no lift shifting. The gentleman at zzp says the lnf turbos are hard on clutches due to the twin scroll turbo. I ended up putting zzp southbend stage 4 in and it's been 2 years. I think it's because my tune allows full boost so early. Every clutch disc I pulled out still looked brand new, even after 40k. Running 23 psi and full bolt ons. Been meaning to get to a decent tuner and get it redone
i replaced the throw out bearing twice so far once for the clutchmasters then a stock one for the stock clutches. im pretty hard on the car but thats cuz im able to fix it pretty easy, zzp still hasnt sent me my flywheel i ordered on saturday which is why i havent posted up whats up. subframes down but waiting to drop the tranny so i can get everything done in 1 day
Alpine_Canada
Feb 12, 2009 04:51 AM
