blown tranny?
Old Nov 30, 2019 | 12:50 PM
bahoodle's Avatar
Thumbs up blown tranny?
so its a 2008 lnf, im on the 5th clutch i put it in probably 5000 miles ago, anyways it shifts pretty crunchy into every gear n wen i let the clutch out i hear a winding noise, does it sound like a tranny issue or just have another broken clutch!? pray for me that its my clutch. ill have a answer in 2 hours wen hopefully pieces of the clutch hit me in the face lmao
Old Nov 30, 2019 | 12:52 PM
Edit. Reading the post again. It's hard to tell since with the clutch not engaged you have a sound. Could be either
Old Dec 1, 2019 | 08:54 AM
QuickSilver_SS's Avatar
How have you went through 5 clutches? I am still on my original stock clutch from day one that the factory installed. And I'm tuned. I assume you must drive hard ? What kind if clutches have you used that have all failed so quickly ?
Old Dec 1, 2019 | 02:00 PM
T-Man's Avatar
Dude.... 5 clutches?
Old Dec 1, 2019 | 03:45 PM
bahoodle's Avatar
yep 5 of em its been outstanding n i had 3 oem clutches n 2 stage 4 clutchmasters but i been using the stock flywheel this whole time n just bought a aluminum zzp flywheel yesterday since there was a discount. the hub like breaks away from the center n it breaks the arms that hold the springs in place im assuming my flywheel may have been bent or warped or my input shaft on the tranny is bent if this one breaks im gonna assume my input shaft is bent
Old Dec 1, 2019 | 03:48 PM
bahoodle's Avatar
i did manage to get a job at a shop from the experience this pile of car has given me tho which is cool haha
Old Dec 8, 2019 | 11:07 AM
victory_red_SS's Avatar
LSX RWD S/C conversion
Through out all 5 of your clutches, have you ever changed the throw out bearing? I would be looking there to ensure it is engaging properly.
Old Dec 8, 2019 | 11:17 AM
C0balts5's Avatar
I can second that, I've snapped the factory one, 2 fx100 clutchmasters. I've never dumped mine or used the factory launch control or no lift shifting. The gentleman at zzp says the lnf turbos are hard on clutches due to the twin scroll turbo. I ended up putting zzp southbend stage 4 in and it's been 2 years. I think it's because my tune allows full boost so early. Every clutch disc I pulled out still looked brand new, even after 40k. Running 23 psi and full bolt ons. Been meaning to get to a decent tuner and get it redone
Old Dec 8, 2019 | 05:25 PM
bahoodle's Avatar
i replaced the throw out bearing twice so far once for the clutchmasters then a stock one for the stock clutches. im pretty hard on the car but thats cuz im able to fix it pretty easy, zzp still hasnt sent me my flywheel i ordered on saturday which is why i havent posted up whats up. subframes down but waiting to drop the tranny so i can get everything done in 1 day
Old Dec 8, 2019 | 10:05 PM
63 Nova SS's Avatar
Might want to rename the title "blown trans" because blown tranny can mean other things now a days.
Old Dec 8, 2019 | 10:07 PM
Old Dec 8, 2019 | 10:17 PM
C0balts5's Avatar
He's right. Lots of snowflakes and weirdos now
Old Dec 8, 2019 | 10:18 PM
bahoodle's Avatar
you rascals lmao
Old Dec 8, 2019 | 10:30 PM
C0balts5's Avatar
I saw this the other day and had to share it cause I thought it was hilarious
tidwell.brandon
Oct 28, 2010 06:34 PM
Alpine_Canada
Feb 12, 2009 04:51 AM
cobaltssoverbooster
Jan 7, 2009 10:17 PM
louiefan
May 30, 2007 11:19 PM
CobaltBurst
Jun 22, 2006 08:58 AM
