Boost=No Data and Three CEL codes HELP
Okay, yesterday while driving I did a few full boost pulls to 100, afterwards my RPD says no data available for Boost only, and its now throwing these three codes:
PO443-Evap Purge
PO0033-Circuit continuity open
PO0107-i cant find.
Any ideas what the PO0107 is and how to make my car read boost again?
Stock tune.
Thanks, Andrew
PO443-Evap Purge
PO0107-i cant find.
Stock tune.
Thanks, Andrew
Wheres the map sensor located?
Would this work for a replacement?
3 Bar MAP Sensor 55206797 - Crate Engine Depot
0107 is a dead MAP sensor and that's why you are getting Blank Data. Replace the MAP sensor, and its usually the one on the INTAKE MANIFOLD from what Ive seen, NOT the Charge Piping. Also, you can't just buy GMS1 sensors and run those, you will need a new tune for them.
