boost controller
boost controller
ok i tried searching to no avail, but on the electric one that comes stock on the turbo has 3 hoses. one from each side of the compressor to the solonoid then to the wastegate. how do you hook up a manual boost controller to this(removing the stock boost controller) or does anyone know?
If you look at the pill mod thread, there is a pic of where to insert the "pill". Just insert the MBC inline like it was the "pill" and you're set.
As stated tho, it makes the boost come on like a light switch lol.
well, i cant use the bcs im a turbo swapped 2.2
so i kind of have to run a mbc
60-100 in 4 secs? wow, my 2.2 took 15 stock.
ok it goes in the line to the waste gate but leave the bcs on there. also on the bpv does the hose from it go straight to the air intake nipple? or somewhere else first?
so i kind of have to run a mbcok it goes in the line to the waste gate but leave the bcs on there. also on the bpv does the hose from it go straight to the air intake nipple? or somewhere else first?
Last edited by 09blackonblack; Mar 3, 2010 at 10:24 AM. Reason: Automerged Doublepost
On a LNF it goes to a solenoid mounted to the intake manifold.
Are you using a LNF's turbo on a 2.2 Balt? If so, then yes, you want to connect that BPV just to a vacuum source.
ok... the nipple on the piping right after the maf is where it blows back into the intake right? im so confused with this part. im considering saying f it and use an hks ssqv like i was going to originally
