Boost controller help
Old Jul 21, 2011 | 10:50 AM
paintballerr78's Avatar
I have a pwerks turbo kit on my car and a turbo xs boost controller. Now no matter how much i turn it up the boost wont go up at all. The wastegate spring is a 14 im pretty sure when i turn the wastegate all the way down its at 14lbs. I turn it up to the point where it wont turn anymore. What could the problem be
Old Jul 21, 2011 | 10:56 AM
silverbullet08's Avatar
Vacume leak... bad boost controller.... wastegate stuck open... kinda need a little more info on your set up. Was it working then just quit?
Old Jul 21, 2011 | 11:08 AM
ya it was working the one day then it just dropped from 20-21 holding to 16 without me even touching the boost controller. has a tial wastegate 14lb spring/turbo xs controller/5557 pte turbo/ZZP BOV
Old Jul 21, 2011 | 04:12 PM
Well found the problem the coupler from my charge pipe to turbo some how ended up resting on the manifold and it melted a hole through it. So now i gotta turn the turbo back a little buy a new coupler then heat wrap that
Old Jul 21, 2011 | 06:27 PM
cobaltssoverbooster's Avatar
wow the mani menlted a charge pipe connector ...holly **** good to hear its an easy fix.
Old Jul 21, 2011 | 06:34 PM
ya i just gotta clock the turbo back then put a new coupler on
Old Jul 21, 2011 | 06:56 PM
Fastgti69's Avatar
thats some intense **** dude. How is your car with the pwerrks kit, you got any dynos?
Old Jul 21, 2011 | 06:57 PM
not yet im going home in august ill dyno back home on 93 and like 23-25lbs then dyno back in north dakota on e30
turbochargedss2012
Sep 20, 2023 12:17 PM
ColonelMustard
North Pacific
Sep 29, 2015 03:02 PM
Coballin13
Sep 25, 2015 08:43 AM
