boost leak
Old Jan 12, 2012 | 11:03 PM
tomj77's Avatar
boost leak
so i did a boost leak test and i got a decent one on the lower map sensor, looked at it, oring is done, could be from taking it out so often. what size o ring is it? or do i just ask my dealer for one?
Old Jan 12, 2012 | 11:04 PM
ramrod1337's Avatar
Check ced...
Old Jan 12, 2012 | 11:24 PM
05Slowline's Avatar
or go to autozone and get the oring kit
Old Jan 13, 2012 | 08:27 AM
Wangspeed's Avatar
You need a Viton size 202 o ring. I suggest Mcmaster part 5577K202.
Old Jan 13, 2012 | 01:23 PM
tomj77's Avatar
Ya I asked dealer and they say I have to buy the sensor , they don't sell them seperate, so off to napa or Canadian tire
I put silicon around the oring for now, it will hold
Old Jan 13, 2012 | 02:51 PM
Frogstofall's Avatar
Does this work for both stock and 3 Bar sensors?
Old Jan 13, 2012 | 04:06 PM
Wangspeed's Avatar
Oh, oops. The one I gave is very specifically for the 3 bar sensor. I don't know what the stock o ring size is.
Old Jan 13, 2012 | 06:53 PM
tomj77's Avatar
well i did another leak test, and after fixing all the loose clamps that were leaking, breaking one tbolt clamp and scrambling to find another. i tested it to 25 psi, no leak, the silicone works just fine. almost shot the leak tester across the shop though, the clamp holding it into the coupler wasnt enough to hold 25psi, almost flew out. lol now i have to find me another tbolt cause i had to use a worm clamp at the turbo cause i broke one. dammit
Old Jan 13, 2012 | 07:00 PM
SSlobalt's Avatar
Compressed air can kill. You guys be safe out there. I need to put that in my DIY if I didn't already.
Old Jan 13, 2012 | 08:32 PM
guitarenvy's Avatar
k thanks mom
and i would suggest getting the correct map seals from ced also.
Old Jan 13, 2012 | 11:21 PM
tomj77's Avatar
my tester has a gauge so i only went to 25 psi to see if would hold it, usually just goto 15. if there is a leak ull hear it at 15
Originally Posted by guitarenvy
k thanks mom
u show me where on their site and i will, i looked
Old Jan 14, 2012 | 08:28 PM
guitarenvy's Avatar
ok there i found it.
now you look
Old Jan 14, 2012 | 08:34 PM
tomj77's Avatar
now you look
ya i found the 3bar ones but not stock. i bought a oring kit, when i need one im sure i got the right one in there. silicon works fine, its actually what my dealer told me to do after i had already done it. will hold better than just the oring.
Old Jan 14, 2012 | 09:49 PM
guitarenvy's Avatar
oh i should have finished reading this page, i thought you had gm kit for some reason, just assumed i guess.
Now i could be wrong but im pretty sure you can use a fuel tank pressure sensor seal from a gm fuel pump. we throw pumps out all the time with them on it. Never seen them sold separatly otherwise. Hope im thinking of the right seal now...
Old Jan 14, 2012 | 10:08 PM
SSlobalt's Avatar
k thanks mom
turbochargedss2012
Sep 20, 2023 12:17 PM
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
tomj77
Oct 4, 2015 11:39 AM
n20saturn
Sep 30, 2015 12:26 AM
