boosting more question
Old Jan 29, 2009 | 09:15 PM
turbobalt's Avatar
i just raised the boost on my car to 18psi.it this safe?????my buddy has his set to 21psi and hes been racing like that for about 6 months.nothing wrong has gone bad yet.how much can my 09 cobalt hold stock??thnks
Old Jan 29, 2009 | 09:17 PM
platinumrims's Avatar
i could be wrong. well then this won't be any help. i think 23psi is safe.
Old Jan 29, 2009 | 09:21 PM
cobaltssoverbooster's Avatar
22.5 psi is max and you can run that just fine all day long. people have been making 400 whp at 22.5 psi for a while with no trouble other than clutch eventually giving in.
Old Jan 29, 2009 | 09:23 PM
hiltu's Avatar
I read somewhere that GM wrote, saying the engine will make 18 PSI if needed. So if thats correct than you really didn't do much. The whole going up to 18 PSI is all about maintaining 260 hp
steven6870's Avatar
Ive also heard 22-23 psi is safe limit, you can spike up more than that, but it MUST settle back to 22-23 psi. Me personally I would put it at 22 and leave it. Again just my opinion.
Old Jan 29, 2009 | 09:25 PM
turbobalt's Avatar
im getting my car tuned in a week.just trying to find out at how much psi i should tune it at.still trying to fine a good tunning place
Old Jan 29, 2009 | 09:29 PM
psykosteve, trifecta tunes, area 47, btf racing, there are lots of people who can get you settled out
i made my own tune at 22 psi maxing the turbo flow out at 32lbs/min and i have no knock and the cat temps stay under the protection limit. i do smell alot of tires though its fast after a tune you will def love.
hiltu's Avatar
The turbocharger generates maximum boost of 20 psi. Because direct injection cools the intake process compared to port injection, it allows the 2.0L Turbo to safely operate at higher boost and higher compression (9.2:1) than a conventional turbo engine, increasing both output and efficiency.
heres the link: http://media.gm.com/us/powertrain/en...tec/08_LNF.doc
this being stock of course
Old Jan 29, 2009 | 09:30 PM
turbobalt's Avatar
man only if i knew people here in houston so we can help each other or cruis
Old Jan 29, 2009 | 09:33 PM
the lnf turbo can boost more than 23 psi we are just stopped by the pressure tables which end at 255kpa which happens to be 23psi thus after 3 sec of 23psi car runs like crap and throws codes. i can speak for all the tuners in saying, we are impatiently waiting for the cobalt edition of gm stage kit to be release end first quarter so we can make more pressure and hopefully open it up even more.
Old Jan 30, 2009 | 08:15 AM
turbobalt's Avatar
after boosting it up when im speed up the guage goes to 18psi then drops back to 0psi then it doesnt want to boost up no more it cuts off.what does that mean?????
Old Jan 31, 2009 | 12:39 PM
rat's Avatar
rat
How did you increase the boost? If it wasn't with a tune un-do what you did, and get a tune.
Old Jan 31, 2009 | 02:25 PM
turbobalt's Avatar
with manuel boost controler.but i found the problem it was a loose hose.
Old Jan 31, 2009 | 03:59 PM
tune is better thats not so safe i believe
turbochargedss2012
Sep 20, 2023 12:17 PM
brandon04
Oct 21, 2015 07:04 AM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
