borg warner difference from mitsu turbo on regal
Old Mar 15, 2012 | 03:18 PM
ECOTecnik's Avatar
ok so heres the deal... i bought a lnf turbocharger to put on my l61 installed it and it wasnt making boost so i got the turbo off and the guy i bought it off of had a bw and a mitsu turbo he gave me both but the mitsu only had 3k on it so it was a no brainer as to which one to use.... the only thing is the mitsu looks smaller i was wondering if there were any differences in the turbochargers as i still have the bw turbo and if it its indeed bigger id rather use it... but seeing as how the bw and mitsu both make 260hp i wasnt sure if it was all that different...
Old Mar 15, 2012 | 03:21 PM
CudaJoe's Avatar
this sounds like a repost. Im pretty sure you or someone else already asked this same thing maybe back in November.
If the Mitsu is a TD04-19T. Its the same size and makes the same power as the Borg Warner K04 in our cars.
Old Mar 15, 2012 | 05:33 PM
ECOTecnik's Avatar
honestly i just joined maybee anmonth ago and i cant search on my cell.... i have a cavalier so cobalt forums arent really my thing... but thanks for the info sorry if its reposted
Old Mar 15, 2012 | 05:39 PM
SSlobalt's Avatar
I don't remember there ever being a definitive answer on this. I thought the Mitsu made less power. I have one as a backup, in my garage. It doesn't really look any different to me, other than the BPV being sturdier.
Old Mar 15, 2012 | 07:56 PM
ECOTecnik's Avatar
i think its slightly smaller... but i may be wrong... as for flow rates in cfm i cant find any info on either... found compressor maps but i dont speak in lines and dots
Old Mar 15, 2012 | 09:42 PM
Matt M's Avatar
Has someone actually documented a case of a Regal being equipped with the Mitsu turbo from the factory? The Regal we test drove and checked out had a Borg Warner turbo on it.
Old Mar 16, 2012 | 12:16 AM
09CobaltSS1's Avatar
This thread actually made me a bit curious about the differences in the 2 turbos again so I said screw it and mapped out both compressor maps to show similar boost levels and to be honest, assuming I did the math right in my current exhausted state, the Mitsu td04h-19t (assuming this is the correct Mitsu turbo in question) actually slightly out performs the K04 at 26psi in spool speed and rpm range.... but just barely.
The only really noticable difference here seems to be in spool speeds. The Mitsu spools to about 26.1psi by a rediculous 1900rpm and holds it all the way to about 5800rpm while staying within a 65% efficiency range according to the map below.
The K04 on the other hand spooled to about 26.8psi by 3500rpm and holds boost to about 5600rpm while staying within a 65% efficiency range.... hense the infamous "turbo falling on it's face after 5500rpm" quote we are all familiar with. The turbo isn't really so much not spinning as fast (falling on it's face) as it was at say 5000rpm as compared to 6000rpm, it's just no longer flowing enough air to support the engine's flow demands beyond that rpm at the desired boost pressure, so the boost pressure as a result dips off.
Granted I did get a little lazy and didn't use identical boost figures here, so in fairness the Mitsu turbo @ 26.8psi holds boost to about 5650rpm (basically identical to the K04), however that boost level pushed the turbo slightly over the surge line. Even so, this turbo looks to spool up rediculous quick.
If I am off in my math somewhere please feel free to correct me, but it should all be accurate. Anyways, on with the compressor maps.
First the K04:
[IMG][/IMG]
And then the td04h-19t
[IMG][/IMG]
Old Mar 16, 2012 | 08:41 AM
CudaJoe's Avatar
wow pretty good! Im only guessing its the TD04-19T because that one is the only one close enough to what our K04 is. Its in the Kia Optima Turbo which my brother in law has so I got to see it in person. Honestly the compressor housing does look a tad bit smaller but I've seen its performance and its a decent turbo.
As for the regal comment. I agree, I believe its a Borg warner in the Regal. Saw the car at the Baltimore Car&Driver autoshow. Both Regals to be honest (GS and Ti) have the save engine, turbo, and accessory components. NO DIFFERENCE. Its the updated LNF motor. The outlet on the turbo looks smaller though and so does the charge piping.
Old Mar 16, 2012 | 08:43 AM
CudaJoe's Avatar
and true sorry I missed that. I know somebody asked it and it was almost literally worded the exact same way lol. Yeah I dont think anyone had answered it then but that looks like an answer there ^
Old Mar 16, 2012 | 12:56 PM
ECOTecnik's Avatar
im almost 100% sure it doesnt say 19t on the turbo its a td04 but ill have to look when i get the car back in my possesion.... i just want to have the bigger turbo obviously haha
Old Mar 16, 2012 | 12:59 PM
Find out the exact turbo model and I will map it out compared to the K04 if you'd like.... assuming I can find a compressor map for it of course
Old Mar 16, 2012 | 02:00 PM
ecotecturbo's Avatar
There is two different 2.0t the regal offers. One has 220hp and one has 270 i wonder if they have different turbos.
Old Mar 16, 2012 | 03:17 PM
CudaJoe's Avatar
nope same turbo. same engine, same everything. different tunes. I looked at both of them at the car show. They are the same car with a 15k price tag difference. lol. They are both FWD.
Old Mar 16, 2012 | 03:54 PM
SSlobalt's Avatar
Mine says TD04L6--04H*19TK3S-8.5T
Old Mar 16, 2012 | 05:01 PM
ECOTecnik's Avatar
that looks like it haha ill check when i get my car back.... fyi cobalt turbochargers are a pain to put on a cavalier haha
Supercharged06SS
Dec 11, 2022 04:47 PM
biniecki
Oct 25, 2015 02:23 PM
Oct 13, 2015 09:32 PM
maliki778
Oct 1, 2015 07:39 PM
