bov bop ...no boost what happened?
Old Jul 30, 2010 | 07:58 PM
dino75's Avatar
When I bought the car, the previouis owner put an aftermarket bov running with the stock one. So it sounded cool but the cel would come on and off. So I bought a bop. I was told it would remove cel and make bov even louder.the aftermarket bov sounds suspiciously unloud but much worst I'm not boosting. The car is not running right. What did I do wrong? Can I fix this or should I just go back to stock? Helps is appreciated. Thanks
Old Jul 30, 2010 | 08:10 PM
elecblue06's Avatar
BOP? i'm guessing you mean block off plate
I'd honestly take the BOV off .. it doesn't really help.. however if you WANT it on .. make sure your BOV is getting a proper vacuum line to it
Old Jul 30, 2010 | 08:56 PM
SSlobalt's Avatar
Did you put the rubber diaphragm back in with the block off plate? You need that to seal it. If you didn't, you have a huge boost leak. You don't need the spring, you just need the diaphragm.
Old Jul 30, 2010 | 09:02 PM
dino75's Avatar
Ok so I'll just prolly go str8 stock bov. Will 23 psi be fine with a stock bov? I'm sure it will, I'm just looking for assurance
The diafram? Are u talking about the thimbel looking thing that was removed with the spring?
Old Jul 30, 2010 | 09:14 PM
iboost's Avatar
Yea. The black rubber thing that the spring sits inside of...
Old Jul 30, 2010 | 09:23 PM
dino75's Avatar
Ok. Hopefully it works out. Thanks guys
Old Jul 30, 2010 | 09:27 PM
iboost's Avatar
It should. I did the samething the first time I put the block off plate in...
Old Jul 31, 2010 | 05:16 PM
dino75's Avatar
So I put the diaphram back in and now my car is back!! Thanks fellas. She's drvin like a dream!
Old Jul 31, 2010 | 06:50 PM
SSlobalt's Avatar
Point for me.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
