Bov and charge pipe question
Old Feb 6, 2015 | 09:33 AM
SS4speed's Avatar
Sorry for all the questions I'm new to the turbo cobalts... so If I weld the bov flange like zzp did to their pipe... put the block off plate on the bov that is on the car. What else do I need to do to make it right...
Old Feb 6, 2015 | 09:37 AM
Omiotek's Avatar
Maf relocate. Use the treadstone block off plate. Tuning
Or
Bung welded to pipe bung welded to intake pipe, recirculate the bov to the intake and no tuning no maf relocate
Old Feb 6, 2015 | 09:45 AM
SS4speed's Avatar
Or
K i have a ttr block off plate. Will that be ok... and I was going to.get it tune..... maf should be before the bov right
Old Feb 6, 2015 | 11:31 AM
09CobaltSS1's Avatar
That is all going to depend on what setup you go with. If you're doing a maf relocate, the maf is going to be after the bov, which is the most ideal in that situation. If you're doing a recirc setup the maf MUST be located before the turbo to get the most benefits out of a recirc. Thus the maf being long before the bov in this situation.
Old Feb 14, 2015 | 02:33 PM
breds2k's Avatar
Then I have to decide if the cost is worth it.... I just bought a ZZP intake and forge BPV (for my HHR) So ill see how loud that is before I buy a BOV. But
HKS BOV -$269
bov flange $40
maf extension $20?
tune $100-$500
For figure $325 for the sound lol still may do it though!
Old Feb 16, 2015 | 08:55 AM
blueLNFftw's Avatar
DO NOT buy the MAF exention. I had 2 of them for ZZP and all they did was cause MAF failures and error codes.
If you relocated the MAF, cut open the wire loom the MAF connector it in and pull out the MAF wires until the OEM plug reaches the new MAF location. There is plenty of wire to do this. Get some new loom, wrap the wires, and tape it all back up.
Old Feb 16, 2015 | 10:08 AM
I cut my maf harness and soldered wire between the two points. Extended it 18". Works great
Old Feb 16, 2015 | 10:10 AM
blueLNFftw's Avatar
I dont know how your harness runs, but on the LNF the MAF wires run passed where the relocate goes. Opening the loom and pulling them out is a better idea on them.
Old Feb 16, 2015 | 01:30 PM
On the l61 the maf harness is tied into the coilpack harness
Old Feb 16, 2015 | 01:47 PM
SS4speed's Avatar
Good to know.. i was going to order it today... but now I will do what you said
Old Feb 16, 2015 | 01:50 PM
  #36
blueLNFftw's Avatar
That means nothing to me. I have only has SS cars lol.
Old Feb 16, 2015 | 04:29 PM
  #37
Wasnt thinking about that, my bad
Jan 12, 2016 12:01 AM
717ssbalt
Oct 2, 2015 04:01 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
