bov spring upgrade
Old Apr 2, 2009 | 04:55 PM
jaygo7007's Avatar
bov spring upgrade
is there a how to for the bov spring upgrade?
or could someone prefer a shop to install it. thanks
im located in houston texas
Old Apr 2, 2009 | 05:03 PM
ericgt79's Avatar
you take 3 bolts out the cover comes off pull old spring out put new harder spring in put cover back re install 3 bolts and go drive.
Old Apr 2, 2009 | 05:18 PM
Mike09SS's Avatar
def dont go to a shop lol. just follow instructions. not hard at all
Old Apr 2, 2009 | 05:49 PM
reign1's Avatar
repost man
search button. its our friend
yeah real easy. easier if you take the intake off tho.
Old Apr 2, 2009 | 07:18 PM
Stamina's Avatar
I'm in Houston and I did it not that long ago (like two weeks ago). I'll help you this weekend if you need a hand. I'm on the NW side of town.
Old Apr 2, 2009 | 07:21 PM
JayCress's Avatar
I just purchased it too, so they come with directions?
Old Apr 3, 2009 | 12:10 AM
RBC's Avatar
RBC
You don't even need instructions is so easy, but I believe someone on here did a right up. Let me see if I can find it for you.
Here are the directions on the first page of this thread.
Old Apr 3, 2009 | 12:35 AM
Stamina's Avatar
Yeah, here's the cliffnotes from what I did a couple of weeks ago:
1) Let the car cool down for a while *cough*
2) Unclip the airbox
3) Disconnect the recirculation air hose going to the intake.
4) Disconnect the wiring harness from the MAF (wires connected to the intake right after the air box)
5) Loosen the metal strap that holds the air intake on the opening of the turbo inlet and take it off. (The bolt will be on the firewall side of the band)
6) Disconnect the hose going to the tan cap on the turbo, by the inlet if it helps you get to those three bolts easier on the tan cap.
6) Loosen/take out the three bolts holding the tan cap out. I would keep at least one bolt partially in because the tan cap will want to spring out a bit. Just make sure when you're unscrewing the last bolt that you're ready to catch anything if it wants to push outwards (or just hold in with your hand).
7) Swap the springs.
8) Reverse steps to reinstall everything.
*To keep yourself from possibly messing up your MAF sensor, take the connector off of the intake (there's a gray part underneath that you pull back and it unlocks the connector). Don't unscrew the whole sensor assembly out of the intake tube. It looks cool, but it's just a bit more protected if you keep it in the tubing and less chance of losing screws, messing it up, etc.
Old Apr 5, 2009 | 12:44 PM
07touringcoupe's Avatar
are the bov for these cars recirculation or ventin
Old Apr 5, 2009 | 06:02 PM
Stamina's Avatar
They are recirculation type.
Old Mar 10, 2010 | 07:20 PM
nolift2010's Avatar
I know this is an old post but what is a good spring to get. Manufacture, resistance?
Old Mar 10, 2010 | 10:32 PM
Stamina's Avatar
Actually, the one you've got already is already the best one. The Dejon spring will make it louder (it's got more resistance), but will slightly surge the turbo due to it bypassing later (how it makes its louder sound).
Old Mar 10, 2010 | 10:42 PM
MaxVQ35DE's Avatar
stock is best performance, and best for your turbo bearings
Old Mar 11, 2010 | 12:41 PM
20redline's Avatar
jay you should of just asked us its really easy to do
Old Mar 11, 2010 | 02:04 PM
Stamina's Avatar
^ x2
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
HEATON
Oct 16, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
