Bullseye Power Batmowheel for Ko4
Old 02-08-2012, 12:21 AM
  #601
Frogstofall's Avatar
Originally Posted by shawnrandolph
worked there for over 3 years.
Pm me if you want to know more
Thats all I wanna say
And we found out NOS took out some but not no where near as many that get returned exploded every week
You worked at Batmowheel? Thats nuts...
Old 02-08-2012, 12:22 AM
  #602
AWD > FWD
TommyP's Avatar
Originally Posted by Frogstofall
You worked at Bullseye Power? Thats nuts...
fixed...
Old 02-08-2012, 12:25 AM
  #603
Thanks Tommy.
Old 02-08-2012, 04:56 AM
  #604
strazdice's Avatar
what is the main cause for the failures happening Currently?
Old 02-08-2012, 09:30 AM
  #605
Matt M's Avatar
Wow, Shawn. That's pretty bold. You've been here one day and going to war? I remember Dave taking care of you pretty good when you had issues with your car out at our shop. It's surprising that you would be so quick to stab him in the back on the way out the door.
I would take this information with a grain of salt. He thought they were the greatest thing out when he worked there. It's often tough to judge the accuracy of someones "information" when it changes drastically in a short period of time. There is obviously some sort of bias playing a part.
Old 02-08-2012, 09:31 AM
  #606
I'm too JDM for you
BLAZIN07SS's Avatar
sounds like someone got fired
Old 02-08-2012, 09:37 AM
  #607
cubaniche's Avatar
Someones dirty laundry being aired out in public?...IM IN! *sits back and grabs the popcorn*
Old 02-08-2012, 11:22 AM
  #608
shawnrandolph's Avatar
Matt If you would like to keep it off the forums please you know me email. You know as well as I do that working there you cant say much of anything. There was alot more stabbing in the back on the other side when I left for my new job cuz they had no one to do machining
Old 02-08-2012, 01:54 PM
  #609
EXsoccer1921's Avatar
no no, you can continue in the thread.
Old 02-08-2012, 02:00 PM
  #610
Yeah for real. If there are quality or integrity issues, I would like to know all details.
Old 02-09-2012, 02:23 AM
  #611
40rty's Avatar
exploding wheels? Some dude Shawn having worked there and Matt making an appearance?
Matt your the loudest kid in this forum.
Old 02-09-2012, 02:24 AM
  #612
lul at matt being a kid
Old 02-09-2012, 02:25 AM
  #613
i mean....
he's great ...man
Old 02-09-2012, 02:26 AM
  #614
40rty's Avatar
i mean....
he's great ...man
I hope he gets it, he should know what I mean
Old 02-09-2012, 02:43 PM
  #615
AndrewSS/TC's Avatar
ive made two purchases from ZZP they ship that shitttttt fastttttttttttttttttttttt hope this helps.
Old 02-09-2012, 04:12 PM
  #616
Terminator2's Avatar
ps 40rty. its technically only been 2 days since the dyno. people don't work on weekends or after 5. but we can get on the forums and complain at any hour of the night.
I hope it makes more than a stock K-04 that is the whole idea. What I want are stock numbers on that dyno, tuned numbers and tuned numbers with the wheel on same tune as far as DALs, WG DC, timing, A/F, etc. No mustang or dynocom dynos either too much potential for operator error vs a dynojet. Fortys car made a whopping 220 whp 240 wrtq stock on the saame dynojet dyno so 100 whp and 170 wrtq is a decent gain with a few boltons and some E-47 especially considering misfiring autolite plugs (fixed now) and his HPFP could not keep up with the fueling demand at 420 wrtq.
Edit: Ugh ZZPs mustang dyno where their shop LNF car made 242 whp 250 wrtq stock which is pure crap. I have seen at least 10 stock LNF mustang dyno graphs an none made over 215 whp and 220 wtrq stock. The only way a LNF will make 13-15% more power than it should on a mustang dyno is by manipulation of the weight and Cd of the vehicle. That is all I need to know. I wish someone else would test this setup.
Old 02-09-2012, 04:49 PM
  #617
whats funny is that the dyno doesn't matter when you test a stock ko4, and then put on the batmoKo4 and test again. which is what they did. and yes it made more power.
Old 02-09-2012, 04:58 PM
  #618
It does if they mess with any of the user inputs vehicle weight, Cd, etc. What is nice about dynojets is there is no operator inputs that go into figuring HP and torque hence no operator error and consistant results. Care to actually share the results?
Old 02-09-2012, 05:57 PM
  #619
Matt M's Avatar
You need to stop your BS. It's getting old. We have been over this plenty of times. There are a lot of reasons why some cars make more power than others. You also seem to ignore correction factors. LNFs correct for conditions as everyone knows. If you dyno 2 stock lnfs- 1 in poor conditions, and 1 in ideal conditions, they should both make the same power, uncorrected. Then add in the correction factor, and the car that was dyno'd in poor conditions shows a much higher corrected hp number. It is just the nature of boost control by the ecm targetting a specific air load.
Second- we have gone straight from our dyno to another and documented the gains. As stated before, our dyno is typically on the high side for a Mustang dyno, but lower than any Dynojet I have tested on. How much higher or lower varies from every dyno you go to. For example. Go from our dyno to Baker Engineerings Dynojet and you will only pick up a few %, maybe 3-4. Then go straight to VT Engines Dynojet and you will see another 5% or more on top of that(I think they closed shop, though). On the other hand, Livernois' Mustang dyno would typically run 3-4% lower than ours, and Motor City Steel's Mustang just slightly lower than ours. Having said that- does it really matter when you are making a dyno comparison on the same day, same dyno? How could you possibly think that is a bad thing when others are testing at 2 different dynos, months apart and you don't say anything about it. You also never mind the fact that our Mustang dyno is going to do a better job of loading the engine properly rather than just spinning a drum that doesn't act nearly the same as actually driving the car does. The bottom line is- you don't "wish someone else would test this setup." You simply want to talk **** about ZZP.
Old 02-09-2012, 06:02 PM
  #620
Matt M's Avatar
What you are saying makes no sense at all. If you think we are dishonest enough to change the dyno settings in order to make one test look better than another, couldn't we just put a bad tune on the car? It's not like the dyno graph shows ignition timing. Aside from any of that, which wheel is it that you think we favored? I'm having a hard time understand where you are coming from. We have no reason to skew anything, so why would it matter?
Old 02-09-2012, 06:20 PM
  #621
Bleu's Avatar
Here's hoping everything works out. Might be very interested in the wheel.
Old 02-09-2012, 06:27 PM
  #622
Matt M's Avatar
Here's another thing I just thought of- Aren't you the one who claimed 372whp on gas with the stock turbo and a few bolt-ons? And you question our dyno numbers?
Old 02-09-2012, 06:28 PM
  #623
terry11's Avatar
This
Old 02-09-2012, 06:42 PM
  #624
Boosted4's Avatar
Less bickering, more Batmo results please.
Old 02-09-2012, 06:55 PM
  #625
Matt M's Avatar
FWIW, here is the stock dyno chart from when I first got my car. It wasn't even 242. Torque was 242, HP was only 239. I have seen them make 260 on Dynojets. Where is the issue?
Quick Reply: Bullseye Power Batmowheel for Ko4
